Use the Fields Parameter
You may be able to improve performance by using the fields parameter on endpoint calls wherever possible and
by limiting the amount of data you request from the server for each
endpoint call to a specific set.
This section applies to Open Storefront Framework
(OSF).
You should avoid using the default with endpoint calls, since that
will fetch all fields. For example, if you use the default when calling
the getCollections and listProducts endpoints, this would result in a large payload and longer server
response time. Remember that you usually only need a subset of fields
for the UI. For more information, see Understand widgets.
