Use preFilter Parameter with Fields Parameter to Improve Endpoint Performance
The preFilter boolean parameter can be
used with fields parameter to improve endpoint performance, but this
can only improve the performance when the resource being requested
has structural depth.
This section applies to Open Storefront Framework
(OSF).
With flat structure resources, your performance may not improve. By default this feature is not enabled at endpoints. On store side it is enabled on these endpoints.
listSkus: /ccstoreui/v1/skus GET
listProducts: /ccstoreui/v1/products GET
listOrganizations: /ccstoreui/v1/organizations GETFollowing is the example of how to use preFilter parameter with the sku endpoint:
/ccstoreui/v1/skus/?skuIds=ProdId&fields=listPrices.US_Dollar:repositoryId&storePriceListGroupId=US_Dollar&catalogId=reseller&preFilter=trueYou can also use preFilter for listProducts and listOrganizations endpoints same as the /skus endpoint:
The response of these examples may not be same.
Issues with Fields Parameter
The fields parameter does
not provide a performance improvement for the first endpoint invocation
and with non-cached endpoints. If you set preFilter=true, and if the response contains a nested structure and you do not
want nested data always, in those cases if you are using fields parameter
with preFilter flag, you will see a performance improvement.
