Validate SSEs
The server-side extension framework performs validation checks on SSEs to avoid conflicts and errors.
This section applies to Open Storefront Framework
(OSF).
By default, the SSE framework checks the authenticatedUrls and publicUrls property in each SSE's package.json file to determine whether the SSE
has at least one URL that is registered with the main
Express application. If it does, the SSE is considered valid. If at
least one SSE running on the server is valid, network
traffic can be routed to the server.
You can disable this checking for an individual SSE by setting
the validateModule property in the package.json file to false:
"validateModule" : false,
}Retail Digital Commerce also checks whether your SSE ZIP file includes
libraries that are part of the server-side extension framework,
such as Express, Winston, Nconf, or Moment. If these modules
are included in your node_modules folder, they may
cause unpredictable behavior, because the SSE framework
will use the local node_modules copy
instead of the global copy. The SSE framework produces
a warning if you upload an SSE that includes one or more of these
modules. The framework also warns if an SSE's proxy configuration
is invalid.
