View Promotions Created with the REST API
The Promotions list on the Marketing tab in the administration interface displays all your store’s promotions, including promotions created with the Admin API.
This section applies to Open Storefront Framework
(OSF).
Unlike promotions created with the UI, merchandisers can view and edit only basic details for promotions created with the API.
The Marketing tab displays the following information about a promotion created with the API:
- A message that explains this promotion was created with the API and that not all promotion details are displayed here.
- The promotion’s name, description, start date, end date, priority, and whether the promotion is enabled. These are the only details that you can edit on the Marketing tab.
- The type of the promotion (item discount, order discount, or shipping discount).
- Details about coupon codes and the Add Coupon Code button.
You can use the Marketing tab to add and edit coupon codes for promotions created with the API. See Manage Promotions for more information.
You cannot use the Copy button on the Marketing tab to copy a promotion created with the API.
