About the X-CC-MeteringMode Header
The X-CC-MeteringMode header is added
to API requests made by Open Storefront Framework (OSF) and Storefront
Classic, so that calls covered under a billable PageView or billable
Order are not counted as billable External API calls.
This section applies to Open Storefront Framework
(OSF).
When you implement a storefront in OSF, you must ensure that the
X-CC-MeteringMode header is not altered or removed, as that will result in
billing issues. If you remove the header from API calls, you will be charged for the calls that
are missing the header. In addition, you must not add this header to requests that are not made
through OSF, such as for headless storefronts or integrations.
