Create an Extension for a Gateway Integration
You use payment gateway extensions to specify settings for a gateway integration, and to create controls in your administration interface for configuring those settings.
These settings appear on the Payment Processing page’s Payment Gateways tab.
Before you develop an extension, you must generate an ID that you will include in your extension file. After you develop the extension, you install it by uploading it to Oracle Retail Digital Commerce as a ZIP file. For a payment gateway, the directory structure of the ZIP file looks like this:
<extension-name>
ext.json
gateway/
<gateway ID>/
gateway.json
config/
config.json
locales/
<locale>.jsonThe JSON files in this structure are used to set various properties that configure the behavior of the extension. These files are discussed below, using a sample credit card payment gateway extension to illustrate their contents.
ext.json
The ext.json file contains metadata for the
extension. For example:
"extensionID": "c2e6a60e-579a-4190-af3e-5edc0cd8a725",
"developerID": "999999",
"createdBy": "Demo Corp.",
"name": "DemoPaymentGateway",
"version": 1,
"timeCreated": "2021-01-01",
"description": "Demo Payment Gateway"
}Note that the extension ID must match the value generated on the Extensions page in the administration interface. See Install the extension and configure the gateway for more information.
gateway.json
The gateway.json file configures the following
gateway settings:
provider– A label describing the payment provider.paymentMethodTypes– A list of the payment method types supported for the gateway.transactionTypes– A list of supported transaction types for each supported payment type. For a credit card payment gateway, valid values areauthorization,void, andrefund.processors– Including thecard3dsprocessor adds support for 3D-Secure credit card payments.
In the following example, the Demo Payment Provider is configured
to support credit card authorization, void, and refund transactions, and
cash initiate and cancel transactions:
"provider": "Demo Payment Provider",
"paymentMethodTypes": ["card", "cash"],
"transactionTypes": {
"card": ["authorization", "void", "refund"],
"cash": ["initiate", "cancel"]
"processors": {
"card": "card3ds"
}config.json
The config.json file creates user interface
elements in the administration interface for configuring gateway settings.
For example:
"configType": "payment",
"titleResourceId": "title",
"descriptionResourceId": "description",
"instances": [
"id": "agent",
"instanceName": "agent",
"labelResourceId": "agentInstanceLabel"
"id": "preview",
"instanceName": "preview",
"labelResourceId": "previewInstanceLabel"
"id": "storefront",
"instanceName": "storefront",
"labelResourceId": "storefrontInstanceLabel"
"properties": [
"id": "paymentMethodTypes",
"type": "multiSelectOptionType",
"name": "paymentMethodTypes",
"required": true,
"helpTextResourceId": "paymentMethodsHelpText",
"labelResourceId": "paymentMethodsLabel",
"defaultValue": "card",
"displayAsCheckboxes": true,
"public": true,
"options": [
"id": "cash",
"value": "cash",
"labelResourceId": "cashPayLabel"
"id": "card",
"value": "card",
"labelResourceId": "cardLabel"
"id": "includeOrderInWebhookPayload",
"type": "booleanType",
"name": "includeOrderInWebhookPayload",
"helpTextResourceId": "includeOrderHelpText",
"labelResourceId": "includeOrderLabel",
"defaultValue": true,
"public": true
}Notice the following settings in the example above:
- The
configTypeproperty specifies the type of configuration the file contains. For a payment gateway, the value of this property should bepayment. - The
instancesproperty specifies an array of different instances of the resource being configured, which makes it possible to have multiple groups of the same settings in the administration interface. In the example above, there are separate settings created for the storefront, the Agent Console, and preview. - The
typeattribute of thepaymentMethodTypesproperty is set tomultiSelectOptionType, which means that multiple methods can be selected (for example,cardandcash). By default the control created for selecting the methods is a drop-down list, but settingdisplayAsCheckboxestotruespecifies that a set of checkboxes should be used instead. - The
includeOrderInWebhookPayloadproperty creates a checkbox for specifying whether or not to include the order data in the webhook call. - The file specifies a number of resource properties. The labels
used in the user interface are mapped to the resource IDs
in the
<locale>.jsonfiles, as described below.
<locale>.json
You create a separate <locale>.json file for each language supported in your administration interface.
For example, you might have an en.json file
for English, fr.json for French, and de.json for German. These files contain labels that appear
in the administration interface when you select the Payment
Gateways tab. For example:
"resources": {
"paymentMethodsLabel": "Payment Methods",
"merchantIdLabel": "Merchant ID",
"cardLabel": "Credit/Debit Card",
"cashPayLabel: "Cash In-Store Payment",
"title": "Demo Payment Gateway Config",
"description":"Demo Payment Gateway configuration",
"previewInstanceLabel": "Preview Configuration",
"storefrontInstanceLabel": "Storefront Configuration"
"merchantIdHelpText": "Enter your Merchant ID",
"paymentMethodsHelpText": "Select your payment method"
"includeOrderLabel": "Include order data in webhook call?"
}The values of the properties in the file are applied to the corresponding
resource ID in the config.json file. For example,
the value of the paymentMethodsLabel property is
used to set the value of the labelResourceID property
of the JSON object in config.json that specifies
the user interface controls.
