Prevent useEffect() from Executing Unnecessarily
If a component includes the React useEffect() hook, it runs immediately after the component is rendered, and then
each time any of its declared dependencies change. To avoid executing useEffect() unnecessarily, you should construct
your code so that useEffect() runs only when it is
actually needed.
In the following example, useEffect() is invoked
after the component is first rendered, but the conditional statement
ensures that the method’s logic is executed only if any of the variant
options change. The logic is skipped if no option is selected:
useEffect(() => {
// Fire action only if variantOptions exist and an option is changed
if (variantOptions && optionChanged) {
// Get the latest selected item from the options
const currentSelectedItem = getCurrentSelectedItem(variantOptions);
const variantOptionsLite = {};
// Remaining code
}, [variantOptions,variantOptionPermutations, optionChanged, widgetId, action,variantToSkuLookup]);
