EFTLink - Server (static one-to-one)
If the Oracle Retail EFTLink Framework Installation and Configuration Guide was followed properly whereby the choice of the installation type was “server,” then some of the configuration should have been completed automatically, however, further configuration is still required.
Please confirm that the correct number of Server<n> folders have been created, and that the EftlinkConfig.properties file and the core properties file exist and configured.
You can assign a friendly name/description to each EFTLink instance so that it is easier to trace through the logs. To do this, please edit the EftlinkConfig.properties within the EFTLink installation root.
For the number servers specified (“NumServers”) ensure there is a server<n>.description key and that the value set is your preferred descriptive choice.
For example,
NumServers = 4
server1.description = EFT Server 1
server2.description = EFT Server 2
server3.description = EFT Server 3
server4.description = EFT Server 4
It is necessary to copy the EftlinkConfig.properties file held within the EFTLink folder to the installation root of Xstore so they are identical. Please refer to figure 2-2 example configuration for further information.
