Multiple Iterations of the Same Core
It is possible to have two or more iterations of a core. For example, if you had two different endpoints that dealt with specific tender types. Ewallet tenders went to one endpoint whereas standard CC/Debit tenders went to a different endpoint.
Such configuration requires two separate opiretail.properties files. To accomplish this:
Within the
EFTLinkConfig.propertiesfile Core<x> property, you will need to specify the relative working folder for each core.For example:
EPSCore0 = oracle.eftlink.opiretail.OPIRetailCore WorkingFolder:./OPICore1EPSCore1 = oracle.eftlink.opiretail.OPIRetailCore WorkingFolder:./OPICore2 -
In the EFTLink installation folder, create the declared sub folders and place the tailored
opiretail.propertiesinto their own subfolder.
