Activating and Deactivating Customer Modules
Customer administrators can activate or deactivate customer-provisioned applications or modules by interacting with the toggles for each row's Active column.
Figure 11-4 Customer Modules Management Page's Toggle Components for Active Statuses
Customer Modules Management - Toggle Components
Only "Application" or "Module" typed rows can be toggled.
Toggling the active state of an application or module also toggles the state of child modules.
When a parent application or module is deactivated, its child modules will be deactivated and their toggle components will be disabled. Activating the parent, activates the child modules and enables their toggles.
