Calling the Seed Service
In most cases it should be sufficient to let the application navigator page or seed utility call the seed service to upload seed data. However, in some cases, such as migrating configurations, a direct call may be more convenient. The seed service exposes a single endpoint/seed that can be called with either GET or PUT methods.
Calling the endpoint with GET will return the entire configuration of the Retail Home instance. Calling the endpoint with PUT allows uploading the configuration in the same format.
