Creating OAuth Client Apps
The application navigator screen allows you to create new OAuth client applications in IDCS or OCI IAM for authentication. This is only available for applications that have a platform service URL configured. The dialog can be opened by selecting Create IDCS OAuth 2.0 Client from the Actions menu. There is no corresponding task bar button.
This dialog takes the following values:
  • The App Name is 2-100 characters and will be used as the name in IDCS or OCI IAM.
  • Description is a detailed description of the application.
  • Scope allows multiple scopes to be defined on the client. These scopes must already exist in IDCS or OCI IAM and should be provided as fully-qualified scopes (FQS), such as "rgbu:rh:service".
When the application is created, another dialog will open to show the client ID and client secret of the new application. These values should be copied down to a safe location, as they will only be shown once. Retail Home cannot retrieve the credentials again after the dialog is closed.
