Export Current Configuration
The Export Current Configuration option exports the configurations in the form of a JSON file. This JSON file can be used to import the same configuration into another Retail Home application.
Figure 13-3 Export Current Configuration Pop-up Window
Figure 13-4 Open or Save Exported Configuration JSON File
