Resources and Customizations Explained
All text resources in the Oracle Retail application have the following values:
  • Base Application Code - This value identifies the Oracle Retail application that owns this text resource.
  • Language - This value identifies the language of the text resource.
  • Bundle - This value identifies the bundle file where this text resource resides.
  • Resource - This value is the unique name that can be used to get the text for this resource.
  • Base Text - This value is the text provided by the Oracle Retail application. This is the text that will appear in the application by default.
Every text resource in Oracle Retail applications is uniquely identified by the combination of Application Code, Language, Bundle, and Resource.
A resource customization is a change that a retailer made to the text of a resource. In addition to the values above, customizations also have the following values.
  • Custom Text - This is the custom text provided by the retailer for the resource.
  • Current Text (or Text) - This is the text that will actually appear in the Oracle Retail application. If a retailer has provided custom text for the resource, then this value will display the retailer's custom text. Otherwise, it will display the base text provided by the Oracle Retail application.
