Seed Data Format
The format for the seed data JSON is as follows:
Root
| Property (*=required) | Type | Description |
applications |
Array |
Array of Application objects to be configured |
tiles |
Array |
Array of Tile objects to be configured |
dashboards |
Array |
Array of Dashboard objects to be configured |
properties |
Array |
Array of Property objects to be configured |
reports |
Array |
Array of Report objects to be configured |
filters |
Array |
Array of Filter objects to be configured |
Applications
Application entries represent applications registered with Retail Home.
*name |
String |
Name of the application to display in Retail Home. Must be unique. |
applicationCode |
String |
Unique identifier for Retail applications. If the application does not exist it will be created. |
applicationType |
String |
"JRAF" or "ARAF". Indicates which type of application this is when inserting a new application code. Defaults to "JRAF". |
*colorSetId |
String |
Color set to use for the application in Retail Home. See below for supported values. |
*active |
Boolean |
Whether the application is active. Inactive applications are not displayed in Retail Home. |
applicationLink |
String |
The base URL to the application. |
platformService |
String |
The base platform REST service endpoint for the application. |
roles |
Array |
Array of Role objects the application is available to. Each role object has a single property containing the role name: |
Tiles
Tiles define available tiles to be displayed on dashboards.
*tileName |
String |
The name of the tile to display in Retail Home. Must be unique. |
*tileColor |
String |
The color to use for the tile. See below for supported colors. |
url |
String |
The URL to launch when the tile header is clicked. Supports the <app.url> token when associated with an application, which indicates the tile will open relative to the application's |
applicationName |
String |
The name of the application this tile is associated with. Must be one of the applications defined in the seed data. |
Dashboards
Dashboard objects define the unique dashboard associated with a given role in Retail Home.
*jobRoleName |
String |
The job role the dashboard is for. Only one dashboard can be created per role. |
*active |
Boolean |
Whether the dashboard is active. Inactive dashboards are not displayed in Retail Home. |
defaultDashboard |
Boolean |
Whether the dashboard is the default. Default dashboards will be preferentially displayed when opening Retail Home. |
*tiles |
Array |
Array of Dashboard Tile objects on the dashboard. May be empty. |
*regions |
Array |
Array of Region objects on the dashboard. May be empty. |
Dashboard Tiles
Dashboard tiles define an instance of a tile object shown on a given dashboard.
tileSize |
String |
How much space to allocate to the tile. Supported values are "1x1" and "2x2". |
*active |
Boolean |
Whether the tile is active. Inactive tiles will not be displayed in Retail Home |
*tileName |
String |
The name of the tile being displayed. The name must be from the array of Tile objects in the seed data. |
*tileStates |
Array |
Array of Tile States to display on the tile |
Tile States
Tile states are the individual data views on dashboard tiles. Each tile state refers to reports configured for the application and can show both a tile state and expanded report. Reports are drawn from those already configured for the Retail Home deployment.
*tileStateConfigId |
String |
ID of the tile state report to display |
reportName |
String |
Name of custom report to display. Mutually exclusive with |
expandedReportConfigId |
String |
ID of the expanded report to display |
*active |
Boolean |
Whether the tile state is active. Inactive tile states will not be displayed in Retail Home |
*urlConfigurations |
Array |
Array of URL configurations configured as data sources for the tile state. No more than one active configuration per report type is allowed. |
contentFilters |
Array |
Array of ContentFilter configurations mapping filters to corresponding tile states. |
Content Filters
Content filters are a mapping between filters and tile states. Each content filter associates an instance of a filter to a tile state.
*filterName |
String |
The name of the filter to apply. This must correspond to a filter provided in the current seed data. |
required |
Boolean |
Whether the filter is required for this tile state. Defaults to false. |
Regions
Regions are the additional banner and contextual data view located above and beside the tiles in the dashboard. Reports are drawn from those already configured for the Retail Home deployment.
*active |
Boolean |
Whether the region is active. Inactive regions will not be displayed in Retail Home |
*reportConfigId |
String |
ID of the report to display in this region |
*regionId |
String |
Which region this configures. Valid options are "Primary", "Secondary", and "Banner". No more than one configuration per region is allowed on a dashboard |
*urlConfig |
UrlConfig |
The URL configuration set as the data source for the region |
URL Configurations
URL configurations register the data sources for regions and tile states.
*contentType |
String |
Type of report this is configuring. Valid options are "region", "tilestate", "expanded", and "filter". Tilestate and expanded are only valid for tilestates. Region is only valid for regions. Filter is only valid for filters (see below) |
*resourceId |
String |
ID of the service this URL configures. |
*resourceType |
String |
What type of URL this is. Valid options are "REST", "FILE", and "LINK" |
*url |
String |
The URL. FILE type URLs may use relative paths. REST and LINK URLs are strictly validated and must contain a protocol if they do not use replacement tokens (details below). Replacement tokens are only supported for tile states. |
*active |
Boolean |
Whether this configuration is active. Inactive URL configurations are ignored by Retail Home. |
Properties
Properties are used to turn on/off specific functionality on Retail Home.
*propertyKey |
String |
Key defining the Retail Home functionality. Currently " |
*currentValue |
Boolean |
Whether this configuration is enabled. |
Reports
Reports are custom reports configured using templates in Retail Home.
*reportTemplateId |
String |
ID of the template for this report. |
*reportName |
String |
Name of the report. |
useLightBackground |
Boolean |
Whether to use a light background when displaying this report in a tile state. If false, the background will be drawn from the color set of the application. |
*parameters |
Array |
Array of report parameters configuring this report. May be empty. |
Report Parameters
Report parameters are used to configure the template of a custom report. The available and required parameters depend on the template being configured.
*paramPath |
String |
ID of the parameter in the template |
*paramType |
String |
Type of parameter. Valid options are "text" and "boolean". |
*textValue |
String |
Value of the parameter as a string. |
Filters
Filter objects define filters associated with applications.
*applicationName |
String |
The name of the application this filter is associated with. Must be one of the applications defined in the seed data. |
*paramName |
String |
Name of parameter. This is appended to the REST call along with the value. |
*filterName |
String |
Display name of the filter. |
*filterType |
String |
Type of the Filter. Value options are 'MULTISLCT', 'TOGGLECTRL', 'NUMINPUT', 'CHECKBOX' & 'RADIOBTN'. |
*active |
Boolean |
Determines whether this filter is active. |
*urlConfig |
Object |
The URL configuration set for this filter. |
options |
Array |
An array of filter options |
translations |
Array |
An array of translations for the filter |
Filter Translations
Translation objects provide localized strings for filters for a given application
*applicationName |
String |
Name of the application this translation is associated with. Must be one of the applications defined in the seed data. |
*paramName |
String |
Parameter name this translation is associated with. The |
*filterName |
String |
Filter name this translation is associated with. The |
options |
Array |
An array of translated options |
*language |
String |
Language to which the translation needs to be applied. |
*sourceLanguage |
String |
Original language of the base filter |
Filter Options
Filter options store selectable options for filters that rely on a preset list rather than pulling options from elsewhere
*optionName |
String |
Name of the option to display in the UI |
*optionValue |
String |
Value of the option to use when sending data |
*displayOrder |
Number |
Order to display the option in the UI |
*language |
String |
Language to which the translation needs to be applied. Not required for options on the parent Filter object. |
*sourceLanguage |
String |
Original language of the base option. Not required for options on the parent Filter object. |
