7 Report Configuration
This chapter describes the reports that are included with Retail Home along with requirements for their configuration.
Currently there are no report layouts for banner and contextual reports available in the release version of Retail Home
Tile State Reports
These reports are available to use on tile states within an application tile. See Dashboard Configuration for details about configuring tile states and data sources. See the "Appendix: Report Data Requirements" appendix for details about expected payloads from back-end REST services and BI.
Favorites
The Favorites tile state report can be included on an application's tile if that application supports favorites. The Favorites report will display the items (tasks, reports, etc.) that have been marked as "favorite" by the user within the target application. The user can click on a favorite item to launch the favorite item in the target application within a separate browser window.
Favorites Sample
Sample Favortes Tile
Table 7-1 Data Source Configuration
Name
favoritesService
Type
REST
Source
https://{host}:{port}/orase-domain/RetailAppsPlatformServices
Notifications
The Notifications tile state report can be included on an application's tile if that application supports notifications. The Notifications report will display the unread notifications for the current user. The user can click on a notification to launch that notification in the target application within a separate browser window.
Notifications Sample
Sample Notifications Tile
Table 7-2 Data Source Configuration
Name
notificationsService
Type
REST
Source
Two Metric Summary
The Two Metric Summary report displays one or two metrics in a standard layout. The data is retrieved from a service endpoint that conforms to the standard API supported by this report. Currently this report can be used to integrate with Apex. Refer to the Apex Integration section for more details.
Two Metric Summary Sample
Sample Two-Metric Summary Tile
Table 7-3 Data Source Configuration
Name
RetailHomeReportDataService
Type
REST
Source
https://{host}:{port}/path/to/service/endpoint
Eight Metric Summary
The Eight Metric Summary report displays one to eight metrics in a standard layout (requires a 2x2 tile). The data is retrieved from a service endpoint that conforms to the standard API supported by this report.
Figure 7-1 Eight Metric Summary Sample
Table 7-4 Data Source Configuration
Name
Type
REST
Source
Twelve Metric Summary
The Twelve Metric Summary report displays one to twelve metrics in a standard layout (requires a 2x2 tile). The data is retrieved from a service endpoint that conforms to the standard API supported by this report.
Figure 7-2 Twelve Metric Summary Sample
Table 7-5 Data Source Configuration
Name
Type
REST
Source
Four or Six Metric Summary
The Four Metric Summary and Six Metric Summary reports displays one to four (or one to six) metrics plus an optional metrics chart in a standard layout (requires a 2x2 tile). These reports also display a single chart with two series or KPIs. The data is retrieved from a service endpoint that conforms to the standard API supported by this report.
Figure 7-3 Four and Six Metric Summary Samples
Four and Six Metric Summary SampleFour and Six Metric Summary Sample
4- and 6-Metric Sample Graph
Table 7-6 Data Source Configuration
Name
Type
REST
Source
Five Metric Summary
The Five Metric Summary displays one to five metrics plus an optional metrics chart in a standard layout (requires a 2x2 tile). These reports also display a single chart with three series or KPIs. The data is retrieved from a service endpoint that conforms to the standard API supported by this report.
Figure 7-4 Five Metric Summary Samples
Sample Five Metric SummarySample Five Metric Summary
Table 7-7 Data Source Configuration
Name
Type
REST
Source
Table Reports
The Metrics Table, Image Table and Image Metrics One Metric Table, Table reports display data in a tabular layout (requires a 2x2 tile). The data is retrieved from a service endpoint that conforms to the standard API supported by these reports.
Figure 7-5 Metrics Table Sample
Figure 7-6 One Metric Table Sample
Figure 7-7 Image Table Sample
Image Table Sample
Figure 7-8 Image Metrics Table Sample
Table 7-8 Data Source Configuration
Name
Type
REST
Source
ORASE Reports
The Demand Transference and ORASE Offer Optimization reports display metric data in a standard layout (requires a 1x1 tile). The data is retrieved from a service endpoint that conforms to the standard API supported by these reports.
Figure 7-9 Demand Transference Sample
Figure 7-10 ORASE Offer Optimization Sample
Table 7-9 Data Source Configuration
Name
Type
REST
Source
Metric Chart Reports
The Metric Chart reports display only a chart with no metrics on a 1x1 or 2x2 tile. The data is retrieved from a service endpoint that conforms to the standard API supported by these reports.
Figure 7-11 Metrics Chart Sample
Example Metrics Chart
Administrator Dashboard Tile States
There are three tiles on the default administrator dashboard that are not intended for user configuration. The Role Requests, Application Navigator, and Subscriptions tiles and their corresponding tile states are generated by default and do not make use of data sources. They are all set up to display information automatically from within Retail Home.
Tile State Report Templates
Refer to the Custom Tile State Reports Configuration section for details about the available Tile State Report Templates as well as data source configuration requirements for custom reports based on those templates.
