15 Application Property Configuration
The Application Properties Configuration page gives customer administrators the ability to update the properties of Retail Home from the application.
Launching Application Property Configuration
The Application Properties page can be launched from the Retail Home Settings Menu.
![Retail Home Settings Menu Retail Home Settings Menu](img/retail-home-set-menu.png)
Viewing Properties for an Application
To view properties, select the component from the Deploy Name dropdown menu and press the search button. Optionally, add additional search parameters to narrow the results returned. Retail Home properties are configured in RH Rest Services, while the remaining options are platform components.
![Search for Properties Search for Properties](img/search_for_prprty.png)
Modifying Properties for an Application
To modify properties for an application, select the property you wish to change from the list and press the edit button, or select "Edit" from the actions menu.
![Modify Application Property Modify Application Property](img/mdfy_app_prprty.png)
Properties For Retail Home
The following properties can be set to configure components of Retail Home. Configuration of deployment names other than RH Rest Services, or properties besides these, should not be necessary and is beyond the scope of this documentation.
Key | Description |
URL to BI WSDL (for example, |
Whether the BI integration requires OAuth to connect to |
