1 Noteworthy Enhancements
This guide outlines the information you need to know about new or improved functionality in the Oracle Retail Home update and describes any tasks you might need to perform for the update. Each section includes a brief description of the feature, the steps you need to take to enable or begin using the feature, any tips or considerations that you should keep in mind, and the resources available to help you.
Column Definitions
Feature: Provides a description of the feature being delivered.
Delivered: Identifies whether the feature is Enabled or Disabled upon initial delivery.
Scale: Identifies the size of the feature. Options are:
Small: These UI or process-based features are typically comprised of minor field, validation, or program changes. Therefore, the potential impact to users is minimal.
Medium: These UI or process-based features are typically comprised of field, validation, or program changes. Therefore, the potential impact to users is moderate
Large: These UI or process-based features have more complex designs. Therefore, the potential impact to users is higher.
- Customer Action Required: You must take action before these features can be used. These features are delivered disabled and you choose if and when to enable them.
| Features | Module Impacted | Scale | Delivered | Customer Action Required? |
| Configuration of POM Notifications – Schedule and Job Level |
Manage Notifications |
Medium |
Yes |
No |
| Updated Scope for XStore Office OnPrem CARCS App Template |
OAuth 2.0 Client |
Small |
Yes |
No |
| Retaining Filters During Import/Export Configurations |
Import/Export |
Small |
Yes |
No |
