Configuring the RPAS Metric Summary Template
The RPAS (Retail Predictive Application Server) Metric Summary Templates are pre-configured to render metrics sourced from the RPAS services as metric summary tiles in Retail Home. There are templates for all metric summary and table reports.
The template has the following features:
- It allows RPAS services to be called with a configurable context value called the
Tile State Context. This context value will be passed a query parameter
tileStateContext) to the RPAS services. The RPAS services can inspect this value to mutate business logic when calculating the metrics.
- It is tailored for RPAS services standards for REST invocation. Specifically, RPAS
Services will be called with the following characteristics:
- The REST request header
X-Requested-Byis always included with a value oftrue. - The REST request header
Accept-Versionis always excluded.
Administrators for Retail Home can use the Add/Edit Custom Tile State Report dialog to specify the Tile State Context value to be sent to the supporting RPAS service.
Administrators can also specify additional headers to be included and excluded in the REST service calls through the dialog.
