12 Import/Export Configuration
The Import/Export Configuration page gives customer administrators the ability to import or export configurations such as Application, Custom Reports, Dashboard Configurations, and so on.
Launch: The Import/Export Configuration can be accessed from:
- Ask Oracle menu → Configurations & Integrations
- Legacy UI → Settings → Import/Export
Figure 12-1 Import/Export Configuration Page
Export Current Configuration
The Export Current Configuration option exports the configurations in the form of a JSON file. This JSON file can be used to import the same configuration into another Retail Home application.
Figure 12-2 Export Current Configuration Pop-up Window
Figure 12-3 Open or Save Exported Configuration JSON File
Import Existing Configuration
The Import Current Configuration option imports configuration settings from a JSON file. This import overrides the current configuration settings and cannot be undone.
Figure 12-4 Import Existing Configuration Popup Window
Before submitting the import, the administrator has the option to review and update
recognized and unrecognized configuration URLs. They can also remove the
_PREPROD suffix from relevant entries as needed.
