Two Metric Summary
The Two Metric Summary report displays one or two metrics in a standard layout. The data is retrieved from a service endpoint that conforms to the standard API supported by this report. Currently, this report can be used to integrate with Apex. Refer to Oracle Application Express Integration for more details.
Figure 5-3 Example of Two Metric Summary Tile
Table 5-3 Data Source Configuration
| Name | RetailHomeReportDataService |
| Type | REST |
| Source | https://{host}:{port}/path/to/service/endpoint |
