3 Planning and Flex Fact Configuration
Retail Insights supports Merchandise Financial Planning (MFP) data on four separate interfaces, referred to as PLAN1 through PLAN4 tables, Assortment Planning (AP) data on a fifth interface called PLAN5, as well as two IPO Cloud Service-Demand Forecasting forecast interfaces (PLANFC1 and PLANFC2) and four flexible fact interfaces (FLEXFACT1 to FLEXFACT4) for any other external data. Another plan interface (PLAN6) is available in the data warehouse but is not exposed in the front-end for reporting; it is intended for platform integrations that need custom planning data outside the pre-integrated tables. All of these tables have configurable data levels to align with the hierarchy levels used in MFP, IPO Cloud Service-Demand Forecasting, or other source systems, but they must be configured prior to using them. The following section describes how to configure RI flexible interfaces for first-time use.
Setting Data Levels
Perform the following procedure to update the expected data levels for the planning interfaces. These levels determine which values the primary key columns are joined with inside Retail Insights (for example, is your plan at Department level or Subclass level). Each interface can be configured with a different set of levels.
Access the Control & Tactical Center to make updates to the C_ODI_PARAM_VW table.
Search for parameter names in the list below, depending on which interfaces you wish to use:
Table 3-1 C_ODI_PARAM Planning and Flex Fact Parameters
Planning Facts Flexible Facts Planning Forecast Facts RI_PLAN1_CAL_LEVEL
RI_FLEXFACT1_CAL_LEVEL
RI_PLANFC1_CAL_LEVEL
RI_PLAN1_ORG_LEVEL
RI_FLEXFACT1_ORG_LEVEL
RI_PLANFC1_ORG_LEVEL
RI_PLAN1_PROD_LEVEL
RI_FLEXFACT1_PROD_LEVEL
RI_PLANFC1_PROD_LEVEL
RI_PLAN1_SUPP_LEVEL
RI_FLEXFACT1_SUPP_LEVEL
RI_PLANFC1_SUPP_LEVEL
RI_PLAN1_ATTR_LEVEL
RI_FLEXFACT1_ATTR_LEVEL
RI_PLANFC1_ATTR_LEVEL
RI_PLAN2_CAL_LEVEL
RI_FLEXFACT2_CAL_LEVEL
RI_PLANFC2_CAL_LEVEL
RI_PLAN2_ORG_LEVEL
RI_FLEXFACT2_ORG_LEVEL
RI_PLANFC2_ORG_LEVEL
RI_PLAN2_PROD_LEVEL
RI_FLEXFACT2_PROD_LEVEL
RI_PLANFC2_PROD_LEVEL
RI_PLAN2_SUPP_LEVEL
RI_FLEXFACT2_SUPP_LEVEL
RI_PLANFC2_SUPP_LEVEL
RI_PLAN2_ATTR_LEVEL
RI_FLEXFACT2_ATTR_LEVEL
RI_PLANFC2_ATTR_LEVEL
RI_PLAN3_CAL_LEVEL
RI_FLEXFACT3_CAL_LEVEL
RI_PLAN3_ORG_LEVEL
RI_FLEXFACT3_ORG_LEVEL
RI_PLAN3_PROD_LEVEL
RI_FLEXFACT3_PROD_LEVEL
RI_PLAN3_SUPP_LEVEL
RI_FLEXFACT3_SUPP_LEVEL
RI_PLAN3_ATTR_LEVEL
RI_FLEXFACT3_ATTR_LEVEL
RI_PLAN4_CAL_LEVEL
RI_FLEXFACT4_CAL_LEVEL
RI_PLAN4_ORG_LEVEL
RI_FLEXFACT4_ORG_LEVEL
RI_PLAN4_PROD_LEVEL
RI_FLEXFACT4_PROD_LEVEL
RI_PLAN4_SUPP_LEVEL
RI_FLEXFACT4_SUPP_LEVEL
RI_PLAN4_ATTR_LEVEL
RI_FLEXFACT4_ATTR_LEVEL
RI_PLAN5_CAL_LEVEL
RI_PLAN5_ORG_LEVEL
RI_PLAN5_PROD_LEVEL
RI_PLAN5_SUPP_LEVEL
RI_PLAN5_ATTR_LEVEL
RI_PLAN5_SOURCE
RI_PLAN6_CAL_LEVEL
RI_PLAN6_ORG_LEVEL
RI_PLAN6_PROD_LEVEL
RI_PLAN6_SUPP_LEVEL
RI_PLAN6_ATTR_LEVEL
Modify the parameters as needed using the following list of supported values. A value of ALL means the column should be set to a default value of -1 on the data file and it will not be joined with any other dimension in RI during ETL. A value of FLEX# indicates an alternate hierarchy level will be used, such as FLEX1 matching data on the W_PRODUCT_FLEX_D.FLEX1_CHAR_VALUE field. Usage of flex fields assumes that this is the same level also used in Planning applications for the plan data.
Table 3-2 C_ODI_PARAM Planning and Flex Fact Values
Product (PROD) Organization (ORG) Calendar (CAL) Supplier (SUPP) Attribute (ATTR) Plan Source (SOURCE) CMP
COMPANY
YEAR
SUPPLIER
C (for Color)
AP_PLAN1_EXP
DIV
CHAIN
HALFYEAR
PARENT_SUPPLIER
B (for Brand)
AP_PLAN2_EXP
GRP
AREA
QUARTER
ALL
FLAVOR
AP_PLAN3_EXP
DEPT
REGION
PERIOD
FABRIC
CLS
DISTRICT
WEEK
SCENT
SBC
LOCATION
DAY
SIZE
ITEM
CHANNEL
GREGORIANYEAR
STYLE
ITEM_LEVEL1
CHANNEL_COUNTRY
GREGORIANQUARTER
ALL
ALL
PRICE_ZONE
GREGORIANMONTH
FLEX1 -FLEX20
ALL
GREGORIANDAY
FLEX1 – FLEX20
Specific to the calendar (CAL) settings, if you are using DAY or WEEK level calendar and are changing the parameter for any PLAN, FLEX, or FACT table, then you must run the following utility in APEX to make that change. Only updating the parameter in C_ODI_PARAM does not perform any table partitioning or cleanup of related configurations, which this process will do for you. Partitioning is only supported on DAY and WEEK level data, so if you only plan to use higher levels above WEEK, then just update the C_ODI_PARAM setting directly from Control & Tactical Center.
For the function call, specify your target table name along with a value of DAY or WEEK in the process call below. If you already ran this once, but are changing the level to a different value, then run it again for the new value (for example, changing from DAY to WEEK, or WEEK to DAY). When changing the value, existing partitions will be dropped and all data purged in order to reconfigure the interface, so backup any data that needs to be preserved.
BEGIN RI_SUPPORT_UTIL.CONFIGURE_CAL_LEVEL_FOR_TABLE(p_table_name => 'W_RTL_FLEXFACT1_F', p_cal_level => 'DAY'); END; -
For RI customers, raise a Service Request with Oracle Support when all configurations are complete, stating that the Planning Configuration processes must be executed on your environment (provide the environment name and summarize the interfaces you plan to use). Part of the configuration process directly alters the application metadata to use your specified levels, so it currently must be managed by Oracle. This step only applies if you need to use the Reporting functionality of RI. It does not apply if you are only loading data for AI Foundation applications.
The plan source parameter for the PLAN5 interface allows you to select which AP plan intersection you wish to load from. By default, the AP_PLAN1_EXP table will hold SKU/store level plan data and the AP_PLAN2_EXP table will hold style-color/store level plan data. If you will only be using the data for Retail Insights reporting, then it’s best to load the data at SKU/store to enable the maximum amount of reporting across fact areas. The style-color/store data is typically used for fashion customers and may be loaded into RI if you need it for any downstream purposes, such as feeding AI Foundation applications that will run at the style-color level. Style-color plan data will only work in RI reports which are above sku level.
Preparing Data Files
After the interfaces are configured, you must prepare the data files for upload to Retail Insights. If you are using MFP, AP, or IPO Cloud Service-Demand Forecasting Cloud Services, the data can be automatically integrated between applications. This involves a one-time setup process during your Planning implementation to enable the batch processes that move data from PDS to RI, and then enable the RI jobs to consume that data. In that case the rest of this section does not apply. Proceed to the next section on partitioning the tables instead.
If you are uploading data files directly to RI, then there are some rules and guidelines to follow when creating the files:
All key columns on the interface must be populated, even if you have specified "ALL" as the data level. You should use a default value of -1 to populate these fields. This includes the fields PROD_DH_NUM, PROD_DH_ATTR, ORG_DH_NUM, SUPPLIER_NUM, as well as all other columns before the CAL_DATE on the flex interfaces.
The calendar (CAL_DATE) field must always be a date. If loading the data above day level, use the end-of-period date. The format must match the date mask specified on the context (CTX) file.
The PLANNING_TYPE_CODE field was originally used to specify if the plan type was COST or RETAIL, but this makes no functional difference in reporting at this time and can be set to any value.
The VERSION_NUM field specifies the plan version in numerical order, starting with 0. When integrating with MFP, the Original Plan is always version 0, and the Current Plan is version 1. These two versions correlate to OP and CP metrics in Retail Insights metadata. Versions greater than 1 may be used to capture version history in the RI database, and the highest available version will be shown in the CP set of metrics.
The DATASOURCE_NUM_ID field must be provided with a hard-coded value of 1, similar to all other RI interface specifications.
The INTEGRATION_ID field must be provided with a unique value that identifies the record, such as a concatenation of all primary key values.
The data file may use standard RI formatting, which uses pipes (|) as delimiters for the columns, or you may pick other delimiters as needed. You can change the file format options in the CTX file.
The accepted list of data files would align to the interfaces:
W_RTL_PLAN1_PROD1_LC1_T1_FS.dat
W_RTL_PLAN2_PROD2_LC2_T2_FS.dat
W_RTL_PLAN3_PROD3_LC3_T3_FS.dat
W_RTL_PLAN4_PROD4_LC4_T4_FS.dat
W_RTL_PLAN5_PROD5_LC5_T5_FS.dat
W_RTL_PLAN6_PROD6_LC6_T6_FS.dat
W_RTL_PLANFC_PROD1_LC1_T1_FS.dat
W_RTL_PLANFC_PROD2_LC2_T2_FS.dat
W_RTL_FLEXFACT1_FS.dat
W_RTL_FLEXFACT2_FS.dat
W_RTL_FLEXFACT3_FS.dat
W_RTL_FLEXFACT4_FS.dat
All of the files must be packaged into a ZIP file for upload, such as RI_MFP_DATA.zip or RI_EXT_DATA.zip. The zip file for these can be marked as optional (which means the nightly batch will not wait for them to arrive before starting) or required (meaning the batch must receive them every night to start processing). It is standard to mark these files as required, since you do not want the batch to run without your planning data, or the next day's reporting could be inaccurate.
Lastly, you must also provide context (CTX) files for each interface, which specifies the exact columns you are populating with data. This allows you to provide only a subset of the many columns on the interface, as long as the key columns and at least one data column are populated. Each CTX file is named similarly to the interface (e.g. W_RTL_PLAN1_PROD1_LC1_T1_FS.dat.ctx) and contains the file format parameters such as column delimiter and header row counts, followed by a single column of values matching the interface field names. Refer to the Retail Insights Interfaces Guide for complete details on the available fields. Refer to the Retail Analytics and Planning Implementation Guide for complete details on CTX file contents.
Partition Tables
The first planning table (W_RTL_PLAN1_PROD1_LC1_T1_F) requires special partition structures due to its use in integrating data to the AI Foundation applications like Promotion and Markdown Optimization. The other plan tables (PLAN2-6) may also be partitioned but it’s not required to use them with AI Foundation at this time. The flex fact and forecasting tables also require similar partitioning before they can be used. The plan and flex tables have flexible partitions which can be either Day or Week level, depending on the data level you plan to use.
The plan and flex fact partitioning is configured in table C_MODULE_EXACT_TABLE where MODULE_CODE in (PLAN1, PLANFC, FLEXFACT1, FLEXFACT2, FLEXFACT3, FLEXFACT4). Modify the columns PARTITION_COLUMN_TYPE and PARTITION_INTERVAL to be one of the following values:
If your input data will be at Day level, set both columns to ‘DY’
If your input data will be at Week level, set both columns to ‘WK’
You must also enable the partitioning process in C_MODULE_ARTIFACT by locating the rows for MODULE_CODE in (PLAN1, PLANFC, FLEXFACT1, FLEXFACT2, FLEXFACT3, FLEXFACT4) and setting ACTIVE_FLG=Y and PARTITION_FLG=Y. If your plan data will extend into the future, you must also change PARTITION_FUTURE_PERIOD to the number of future months that need partitions built beyond the specified business date (e.g. use a value of 6M to partition 6 months into the future).
Once the configuration steps are completed, you must run the adhoc POM process CREATE_PARTITION_ADHOC to apply them. If you already have nightly batches running, then the ETL date is being managed there, and you must disable both the ETL_BUSINESS_DATE_JOB and W_RTL_CURR_MCAL_G_JOB in this process and only run the two partition jobs by themselves.
Example Postman message body to send to POM via Rest API call:
"cycleName": "Adhoc",
"flowName":"Adhoc",
"processName":"CREATE_PARTITION_ADHOC",
"requestParameters":"jobParams.CREATE_PARTITION_PRESETUP_
JOB=2018-12-30,jobParams.ETL_BUSINESS_DATE_JOB=2021-02-06"
If you disabled the business date jobs, then the process call would be like this instead:
"flowName":"Adhoc",
"requestParameters":"jobParams.CREATE_PARTITION_PRESETUP_JOB=2018-12-30"
If you are entering the parameters from the POM UI instead of Postman, then you must specify each date as the input parameter on the jobs listed above. The first date is added as the parameter on CREATE_PARTITION_PRESETUP_JOB and the second date is added on ETL_BUSINESS_DATE_JOB (if using).
Loading Plan and Forecast Data
The plan and forecast data will be loaded either from flat files or directly from the planning systems. If you are loading from flat file, then you will run the COPY/STG jobs to import the file ata followed by the fact loads (*_F_JOB) and disable any other jobs. If you are loading from Planning directly, then you would use the *_SDE_JOB programs followed by the fact loads (*_F_JOB) and disable any other jobs. The forecast direct-loads are run outside the nightly batch as a recurring flow you can schedule, so that the weekly forecast load does not impact your nightly batch runtimes.
Table 3-3 Dataset Jobs
| Job | Ad Hoc Processes or Flows | Usage |
W_RTL_PLAN1_PROD1_LC1_T1_FS_COPY_JOB W_RTL_PLAN2_PROD2_LC2_T2_FS_COPY_JOB W_RTL_PLAN3_PROD3_LC3_T3_FS_COPY_JOB W_RTL_PLAN4_PROD4_LC4_T4_FS_COPY_JOB W_RTL_PLAN5_PROD5_LC5_T5_FS_COPY_JOB W_RTL_PLAN6_PROD6_LC6_T6_FS_COPY_JOB W_RTL_PLAN1_PROD1_LC1_T1_FS_STG_JOB W_RTL_PLAN2_PROD2_LC2_T2_FS_STG_JOB W_RTL_PLAN3_PROD3_LC3_T3_FS_STG_JOB W_RTL_PLAN4_PROD4_LC4_T4_FS_STG_JOB W_RTL_PLAN5_PROD5_LC5_T5_FS_STG_JOB W_RTL_PLAN6_PROD6_LC6_T6_FS_STG_JOB |
N/A (Nightly Only) |
Load the MFP and AP planning flat files from the server into the staging area in the database. Only used as part of nightly batch processing, flat files cannot be loaded in ad hoc processes. Tables are truncated at the beginning of each execution so new data can be inserted. |
W_RTL_PLAN1_PROD1_LC1_T1_FS_SDE_JOB W_RTL_PLAN2_PROD2_LC2_T2_FS_SDE_JOB W_RTL_PLAN3_PROD3_LC3_T3_FS_SDE_JOB W_RTL_PLAN4_PROD4_LC4_T4_FS_SDE_JOB W_RTL_PLAN5_PROD5_LC5_T5_FS_SDE_JOB |
LOAD_PLANNING1_DATA_ADHOC LOAD_PLANNING2_DATA_ADHOC LOAD_PLANNING3_DATA_ADHOC LOAD_PLANNING4_DATA_ADHOC LOAD_PLANNING5_DATA_ADHOC |
Imports planning data directly from the MFP and AP exports from Planning Data Store (PDS) to Retail Insights. The data is inserted into the staging tables, and assumes you are not providing any data via flat file (each interface should only come from either MFP/AP or flat file but not both). |
W_RTL_PLAN1_PROD1_LC1_T1_F_JOB W_RTL_PLAN2_PROD2_LC2_T2_F_JOB W_RTL_PLAN3_PROD3_LC3_T3_F_JOB W_RTL_PLAN4_PROD4_LC4_T4_F_JOB W_RTL_PLAN5_PROD5_LC5_T5_F_JOB |
Transforms and loads planning data from staging areas into the final fact tables. Used both for the nightly processing and for ad hoc loads. |
W_RTL_PLANFC_PROD1_LC1_T1_FS_COPY_JOB W_RTL_PLANFC_PROD2_LC2_T2_FS_COPY_JOB W_RTL_PLANFC_PROD1_LC1_T1_FS_STG_JOB W_RTL_PLANFC_PROD2_LC2_T2_FS_STG_JOB |
Load the forecast flat files from the server into the staging area in the database. Only used as part of nightly batch processing, flat files are not loaded in the ad hoc processes. Tables are truncated at the beginning of each execution so new data can be inserted. |
W_RTL_PLANFC_PROD1_LC1_T1_FS_SDE_JOB W_RTL_PLANFC_PROD2_LC2_T2_FS_SDE_JOB |
RI_FORECAST_ADHOC |
Imports forecast data directly from the AIF exports to Retail Insights. The data is inserted into the staging tables, and assumes you are not providing any data via flat file. Only the sku/store/week forecasts are pulled by default. |
W_RTL_PLANFC_PROD1_LC1_T1_F_JOB W_RTL_PLANFC_PROD2_LC2_T2_F_JOB |
RI_FORECAST_ADHOC |
Transforms and loads forecast data from staging areas into the final fact tables. Used both for the nightly processing and for ad hoc loads. |
CLEANUP_C_LOAD_DATES_PLANNING_JOB |
CLEANUP_C_LOAD_DATES_PLANNING_ADHOC |
In order to run a planning load more than once in a single business date, you must clear the execution status from the prior run, otherwise the batch process will skip any subsequent loads (until the business date changes). |
Loading Aggregate History
Special flex fact tables have also been provided to support loading of pre-aggregated history fact data for AI Foundation to use to generate forecasts for Planning. These tables should not be used unless there is no other way to provide history data except at a level above item/location. These tables will completely bypass the normal data flow for history in RI and AIF, directly populating history fact tables just for limited AIF use-cases.
These tables work identically to PLAN and FLEX tables described in the previous sections. They use FACT as the table name prefix, for example W_RTL_FACT1_PROD1_LC1_T1_F. Four such FACT tables are provided for the different data intersections that may exist for aggregate actuals. Just like PLAN tables, you must configure these in C_ODI_PARAM_VW in the Control Center using parameters like RI_FACT1_PROD_LEVEL and RI_FACT1_ORG_LEVEL.
Refer to the Retail Analytics and Planning Solutions Implementation Guide section on Loading Aggregate History Data for additional information on how to use these tables.
