Functionality Offered
DDS offers various functionality regarding databases. It can connect to various database connections. The application then discovers the schema inside the databases and allows the user to work and interact with the tables and data within the tables. The high level list of functionalities offered:
                     Schema Discovery
                     Viewing Table Definition
                     Querying table data
                     Creation, modification and deletion of records
                     Bulk Updates and Deletion of data in tables
                     Security setup for limiting data access and modification
