Update Data
This end point updates data in a table using the rowFilter query parameter and input is provided in JSON format. Users that belong to the admin or operator group can only perform this operation. Users also need to have DataUpdatePermission to update data.
HTTP Operation: POST
Path: /resources/dds/{schemaName}/data/{table}?rowFilter=<predicate>
Sample input for updating data in the BDI_SYSTEM_OPTIONS table
/dds/bdi_rms_schema/data/BDI_SYSTEM_OPTIONS?rowFilter=VARIABLE_NAME='LOADJOBDEF'
"VARIABLE_VALUE":"TRUE"
