Enterprise Integration Frameworks and Products
Common Enterprise Integration Infrastructure products provide standards and guidance and remove the complexity from the business applications and provide an accepted solutions to recurring problems within a given integration context. Around these styles and patterns, Oracle Retail has developed a set of Enterprise Integration Infrastructure products and supporting tools.
These products expose hundreds of Oracle Retail Application API's as contract driven integration points exposed for integrations between Oracle Retail applications and customer 3rd Party and Legacy applications.
Retail Integration Bus (RIB) – Asynchronous JMS Messaging
Retail Service Backbone (RSB) – Request/Response Web Services.
Bulk Data Integration (BDI) – Bulk Data Movement
Retail Financial Integration (RFI) – Integration to Oracle Financial Products (EBS, People Soft Financials, Oracle Cloud Financials)
Oracle Warehouse Management Cloud Service integration using the Universal Service Mapper product (USM) - allows the definition, mapping, and configurations needed to support the integration between two heterogeneous applications.
All Integration Infrastructure products are fully cloud enabled and will be deployable as the Oracle Retail Integration Cloud Services and existing integration APIs work without modification for Cloud, Hybrid-Cloud and On-Premise installations.
