Key Benefits
  • Designed using latest industry best practices
  • Canonical objects for retail domain that have been built from integration experience with hundreds of customer use cases
    Table 2-1
    RIB RSB BDI
    Business Entities
    67
    92
    49
    Business Objects
    641
    302
    51
    Integration Flows
    69
    87
    159
    Connected Apps
    13
    24
    13
  • Intended to work out of the box for customers without needing development effort between supported products
  • Only one instance of RICS is required for a customer instance
  • Mature Robust Software - running at hundreds of retailers
  • Backward and forward compatible Integration APIs - Upgrade Ready
  • Mixed version integration capable, tools provided
  • Third-party integration ready with build in extension/customization hooks
  • Security, monitoring, alerts, logs and so on.
  • Strong focus on customer self-service
