The Retail Integration Suite of Products
The Suite is a set of integration infrastructures that are specifically designed to solve retail enterprise integration use cases.
The Suite is made up of hundreds of Pre-built Business Processes that work out of the box for retailers. The process is made up of hundreds of Pre-built Business Objects that are fully tested and supported in end-to-end integration flows for specific to the retail industry.
