ApplicationMessages.xsd
<?xml version="1.0" encoding="UTF-8" ?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.oracle.com/retail/integration/rib/ApplicationMessages/v1"
xmlns:rib="http://www.oracle.com/retail/integration/rib/ApplicationMessages/v1"
xmlns:jaxb="http://java.sun.com/xml/ns/jaxb"
xmlns:xjc="http://java.sun.com/xml/ns/jaxb/xjc"
jaxb:extensionBindingPrefixes="xjc"
jaxb:version="2.0"
targetNamespace="http://www.oracle.com/retail/integration/rib/ApplicationMessages/v1"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:annotation>
<xs:appinfo>
<jaxb:globalBindings
fixedAttributeAsConstantProperty="false"
choiceContentProperty="true"
enableFailFastCheck="true"
generateIsSetMethod="true "
enableValidation="true">
<!--xjc:javaType name="java.util.Calendar"
xmlType="xs:dateTime"
adapter="com.oracle.retail.integration.rib.rib_integration_runtime_info.datatypeadapter.CalendarAdapter"/ -->
<jaxb:serializable uid="1"/>
</jaxb:globalBindings>
<!--jaxb:schemaBindings>
<jaxb:package name="com.oracle.retail.integration.rib.ribintegrationruntimeinfo" />
</jaxb:schemaBindings-->
</xs:appinfo>
</xs:annotation>
<xs:element name="ApplicationMessages">
<xs:complexType>
<xs:sequence>
<xs:element ref="ApplicationMessage" maxOccurs="unbounded" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="ApplicationMessage">
<xs:complexType>
<xs:sequence>
<xs:element name="family" type="string25"/>
<xs:element name="type" type="string30"/>
<xs:element name="businessObjectId" type="string255" minOccurs="0"/>
<xs:element ref="ApplicationMessageRoutingInfo" minOccurs="0" maxOccurs="unbounded"/>
<xs:element name="payloadXml" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="ApplicationMessageRoutingInfo">
<xs:complexType>
<xs:sequence>
<xs:element name="name" type="string25"/>
<xs:element name="value" type="string25"/>
<xs:element ref="ApplicationMessageRoutingInfoDetail" minOccurs="0" maxOccurs="2"/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="ApplicationMessageRoutingInfoDetail">
<xs:complexType>
<xs:sequence>
<xs:element name="value" type="string300"/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:simpleType name="string255">
<xs:restriction base="xs:string">
<xs:maxLength value="255" />
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="string25">
<xs:maxLength value="25" />
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="string30">
<xs:maxLength value="30" />
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="string300">
<xs:maxLength value="300" />
</xs:restriction>
</xs:simpleType>
</xs:schema>
