Configure External Job Admin as Receiver in the Process Flow
System options properties in bdi-process-flow-admin-deployment-env-info.json allow you to configure the available destination apps and appsInScope.
allAvailableDestinationApps property mentions all the applications available as destination.
The appsInScope property mentions the applications that are in scope. Add an external application in the appsInScope property to make it available as a receiver.
"SystemOptions":[
{"name":"allAvailableDestinationApps", "value": "SIM, RPAS, EXTERNAL, OCDS, RFI, RMS"},
{"name":"appsInScope", "value": "SIM, RPAS, OCDS, RFI, EXTERNAL"}
