A Appendix: RIC Installation Checklist
| Property Name in the JSON file | Description | Editable? | Sample Value |
RicDataSource |
dataSourceName |
Name of the datasource, the installer will create to connect to the database |
NO |
N/A - DO NOT CHANGE THE DEFAULT VALUE |
dataSourceClass |
DataSource class, the installer will use to configure the data source |
NO |
dataSourceJndiName |
JNDI name used by RIC application to connect to the database |
NO |
dbcUrl |
DBC URL used by RIC application to connect to the database |
Yes |
jdbc:oracle:thin:@//dbserver.example.com:1521/pdborcl |
jdbcUserAlias |
JDBC User Alias used by RIC application to connect to the database |
NO |
jdbcUser |
JDBC User Name used by RIC application to connect to the database |
NO |
jdbcPassword |
JDBC Password used by RIC application to connect to the database |
NO |
RicAppServer |
weblogicDomainName |
Name of the Weblogic domain on which RIC application will be deployed |
Yes |
ric_domain |
weblogicDomainHome |
Absolute path to the Weblogic domain |
Yes |
/user/local/Oracle/Middleware_home/Weblogic12.2.1.4.0/21.0.000user_projects/domains/ric_domain |
weblogicDomainAdminServerUrl |
Weblogic Admin Server URL of the domain being used for deployment of the app. |
Yes |
t3://example.com:7001 |
weblogicDomainAdminServerProtocol |
Weblogic Domain Admin Server Protocol, the protocols used for the deployment of the app. |
Yes |
t3/t3s |
weblogicDomainAdminServerHost |
Name of the host machine where Weblogic server is installed. |
Yes |
example.com |
weblogicDomainAdminServerPort |
Weblogic Domain Admin Server Port |
Yes |
7001 |
weblogicDomainAdminServerUserAlias |
Weblogic Domain User Alias, installer will use to bind the user to the Weblogic server admin user |
NO |
weblogicDomainTargetManagedServerName |
Weblogic Domain Managed Server Name, the name of the managed server on which RIC application will be deployed |
Yes |
ric-server |
ricUiUserGroup |
RIC UI User Group, the name of the User Group authorized to access RIC GUI |
NO |
ricUiUserAlias |
RIC UI User Alias, installer will use the alias to bind the user with the application |
NO |
ricUiUser |
RIC UI User, installer will retrieve the username from wallet and create the user on Weblogic. This user name should be used to login to the app. |
NO |
ricUiPassword |
RIC UI Password, installer will retrieve the password from wallet and create the user on Weblogic. This password should be used to login to the app. |
NO |
secureCookie |
Flag to secure Cookies. |
Yes |
true/false |
IntegrationProduct |
ribEnable |
Flag to enable or disable RIB for RIC. Edit this property to change RIB mode |
Yes |
true/false |
bdiEnable |
Flag to enable or disable BDI for RIC. This property value is not used in current version of RIC. By default, false. |
NO |
ribHome |
RIB home path, this property should point to valid rib-home on the same machine if ribEnable is set to true. The value should be in the specified format in sample value. |
Yes |
user@example.com:/user/local/integration/rib-home |
bdiHome |
BDI home path, this property should point to valid bdi-home on the same machine if bdiEnable is set to true. The value should be in the specified format in sample value. By default, can be same as ricHome.This property value is not used in current version of RIC. |
NO |
