External Application as a Publisher (rest-app) using OAuth2
For external applications to publish to the RIB JMS on cloud, it needs to use a publishing webservice provided by rib-ext.
The end point of publishing service follows below pattern:
Table 4-1 Publishing Service Pattern
Resource | HTTP Method | Endpoint |
Ping |
GET |
GET http://<external_LB_url>/<rics-sub-namespace>/rib-ext-services-web/resources/publisher/ping |
Publish |
POST |
http://<external_LB_url>/<rics-sub-namespace>/rib-ext-services-web/resources/publisher/publish |
RIB-EXT publishing service REST endpoints are protected using OAuth2 token-based authentication meaning end points are accessible by sending along an access token.
Scope will be used for authorization of REST services. Scope for RICS is in the following format- rgbu:rics:RICS-<Environemnt Type><Environment Index> (that is, rgbu:rics:RICS-DEV1).
Client Credentials grant type is supported.
For getting access to RICS publishing service you need to create a client app in IDCS. IDCS app generates an access token that will be used for making publishing service calls. Follow steps for creating the client app in IDCS.
