Oracle Retail Bulk Data Infrastructure (BDI)
Batch (Bulk) data is still a predominant integration style within Oracle Retail and its customers. The movement of bulk data remains important because some work is best suited to being performed in bulk. Batch processing was there in the early days; it is still here today; and it will still be here tomorrow. What has changed is the approach to batch processing.
BDI Architecture and Design is to be On-Premise and Hybrid Cloud ready.
Lightweight UI's and services provide full coverage and are both customer facing and operations facing.
BDI Provides a fully service enabled, fault tolerant, concurrent, high throughput infrastructure
BDI Transport layer moves data via services, not files.
Provides integration job process scheduling and is fully instrumented to provide end-to-end visibility and re-startability.
Automated restart recovery at a granular level.
BDI-EXT
BDI is an integration infrastructure product which can integrate Oracle Retail applications to third party applications. BDI external application is designed to address the complexities for third party integration with Oracle Retail application. In BDI, bulk data movement happens between sender and receiver application. External application can only be a receiver.
Please refer to the Oracle Retail Bulk Data Integration Guide – Concepts for the details
BDI is an integration infrastructure product which integrates Oracle Retail applications and third-party applications. BDI Bulk Data Export Service is designed to address the complexities for third party integration with Oracle Retail application. In BDI, bulk data movement happens between sender and receiver application.
Please refer to the Oracle Retail Bulk Data Integration Guide – Integration with External Applicationsfor the details
