RIB-EXT Side of Configuration to Point to External Application
Below are the steps to point rib-ext to the correct injector service.
Table 4-2
Category Step Comment
Access RIB Admin GUI
Access the rib admin GUI at https://<external-load-balancer>/rib-ext-admin-gui
Log in with the admin user.
login
Verify Configuration and update
Navigate to Manage Configurations -> System options
Search for and verify the following:
  1. destination.retail.appType: rest-app
  2. Update the value for InjectorService URL (injector.service.endpoint.url). URL should point to inject service provided by external application. (e.g.- https://<host:port>/rib-injector-services-web/resources/injector/inject
  3. Security Policy (injector.service.security.policyname) : policyA
  4. IDCS OAuth Server URL (oauth2.default.authorizationServerUrl): https://<idcs-tenant>/oauth2/v1/token
  5. OAuth2 Token Scope: Default (i.e.- urn:opc:idm:__myscopes__)
verify configuration
Supported Grant Types for OAuth2
There are two grant type supported. Based on the use case follow steps below.
Steps for grant_type as password
Update username and password
Navigate to Manage Configurations - > Injector Service
Update details
  1. Choose rib-ext_ws_security_user_name_alias from drop down.
  2. Update rib-ext_ws_security_user_name_alias with valid username/password.
  3. Click on Save.
update username and password
Update ClientID/Secret needed for token generation
Choose rib-ext_oauth2_application_client_user-name-alias from drop down and update details
  1. Provide a valid Client ID in username.
  2. Provide a valid Client Secret in password.
  3. Click on Save.
update client ID
How to verify provided injector service details are correct
Verify if the provided injector service URL and credentials are correct for grant_type password using curl.
Execute the following curl commands for grant_type password:
ClientId=56c7eb72f11b43bb98bf2570fa2353eb
ClientSecret=bb18aa22-4bb4-41d1-9ed4-fea276651e28
IDCSUrl=https://idcs-24e4baae56764e91be371e6a2060d66e.identity.c9dev2.oc9qadev.com
un=integrationUser
pw=Welcome@1234
AccessToken=$(curl -i -X POST \
--user $ClientId:$ClientSecret \
-H "Content-Type: application/x-www-form-urlencoded;charset=UTF-8" \
$IDCSUrl/oauth2/v1/token \
-d "grant_type=password&username=$un&password=$pw&scope=urn:opc:idm:__myscopes__" | grep -o -P '(?<=access_token":").*(?=","token_type)')
echo $AccessToken
ribExtServiceUrl=https://<external-app-load-balancer>/rib-injector-services-web/resources/injector/ping
curl -ivkL --noproxy '*' -H "Authorization: Bearer $AccessToken"  -H "Content-Type: applica-tion/xml" -X GET $ribExtServiceUrl
if you get a 200 response, then the configuration is correct
if you get 401 unauthorized, then Client ID and secret are incorrect
Steps for grant_type as client credentials
Update username and password to empty
Update details.
  1. Choose "rib-(app)_ws_security_user-name-alias" as Secured User Alias.
  2. Update the Secured User Name with a blank userName.
  3. Update the Secured User Password with a blank password.
  4. Click on Save.
Update details
  1. Choose "rib-(app)_oauth2_application_client_user-name-alias" as Secured User Alias.
  2. Update the Secured User Name with clientID.
  3. Update the Secured User Password with clientSecret.
updae client ID
Ping Test
Navigate to Manage Configurations -> RIB Service Monitor
  1. Click on ping
  2. It should return success
ping test
Verify if the provided injector service URL and credentials are correct.
AccessToken=$(curl -i -X POST \ --user $ClientId:$ClientSecret \ -H "Content-Type: applica-tion/x-www-form-urlencoded;charset=UTF-8" \
$IDCSUrl/oauth2/v1/token \ -d "grant_type=client_credentials&scope=urn:opc:idm:__myscopes__" | grep -o -P '(?<=access_token":").*(?=","token_type)')
ribExtServiceUrl=https://rgbu-phx-lbext-351.us.oracle.com/rib-injector-services-web/resources/injector/ping
