8 Integration with External Applications
RIBforExt is the Oracle Retail Enterprise Integration component designed to address the connectivity requirements for 3rd Party integrations in a hybrid cloud topology where the RIB is deployed in the Retail Integration Cloud Services.
In a hybrid cloud scenario customers no longer have access to RIB's JMS server and cannot directly publish and subscribe to messages on the JMS topics. The RIB-EXT app is designed to fill that gap, it provides Web Service based APIs to publish to and subscribe from the RIB's JMS from third party systems.
RIBforEXT has all of the RIB flows available for the deployment time configuration based on the customer use cases.
RIB-EXT out-of-the-box provides the complete set of publishers, subscribers and retry adapters needed for the external application to integrate with Oracle Retail applications using RIB infrastructure.
The selective list of publisher and subscriber adapters needed by each specific external application is defined by the customer's implementation team.
Integration Diagram
Implementing RIB-EXT
RIB-EXT is an Oracle Retail Integration Application that provides necessary communication channel for external applications to publish and consume message from RIB's JMS on cloud and premise.
BasicAuth will no longer be supported starting from the RICS v24 release. RICS will enforce OAuth2 as the required authentication mechanism using the IDCS authenticator. Oauth2 is being enforced for authorization for ongoing security reasons and to ensure the customer stays within their OCI IAM limits. Customer/SI partner are advised to prepare for this change and implement OAuth2 for both inbound and outbound calls via RIB-EXT.
RICS is also enforcing environment specific Oauth scope for authorization of inbound web service calls (RIB-EXT). The scope pattern that is used in the RICS IDCS app creation template is rgbu:rics:RICS-<ENVIRONMENT> where ENVIRONMENT is the environment type (STG, PRD, UAT, DEV1, DEV2, and so on). For details Refer Section: Create OAuth2 Client Application in IDCS.
How to Send/Receive Messages to/from the RIB System
For third-party integration, RIB-EXT provides ReST API’s for external applications to send and receive data from the RIB system. The following sections cover the implementation details.
External Application as a Publisher (rest-app) using OAuth2
The end point of publishing service follows below pattern:
Table 8-1 Publishing Service Pattern
Resource HTTP Method Endpoint
Ping
GET
GET https://<external_LB_url>/<rics-sub-namespace>/rib-ext-services-web/resources/publisher/ping
Publish
POST
https://<external_LB_url>/<rics-sub-namespace>/rib-ext-services-web/resources/publisher/publish
  • RIB-EXT publishing service REST endpoints are protected using OAuth2 token-based authentication meaning end points are accessible by sending along an access token.
  • Scope will be used for authorization of REST services. Scope for RICS is in the following format- rgbu:rics:RICS-<Environemnt Type><Environment Index> (that is, rgbu:rics:RICS-DEV1).
  • Client Credentials grant type is supported.
For getting access to RICS publishing service you need to create a client app in IDCS. IDCS app generates an access token that will be used for making publishing service calls. Follow steps for creating the client app in IDCS.
Use Retail Home for creating the client app in IDCS. Once app is created you will get client id and client secret both of them necessary to get access token. Follow the instructions below for generating the access token and making service call using OAuth2 token.
  1. Login into retail home as retail home administrator.
    login
  2. In retail home screen click on Settings menu icon on the left and then click on Application Administration.
    application administration
  3. On the Application Administra-tion menu click on Application Navigator Setup. Notice all the hosted applications are listed here with their application and plat-form service url.
    Settings -> Application Administration->Application Navigator Settings
    application navigator setup
  4. Look for application with name RICS. If you are not seeing RICS application try refreshing seed. Steps
    1. Select the row with the application code as Rms.
    2. Click the Refresh Seed Data button on top right corner of the menu.
    3. Wait for some time and refresh the screen.
    4. RICS should reflect now.
    RICS application name
  5. If RICS application is not reflecting even after following step 4. Select the row with the application code as Rms and click on the Actions menu on top left. Select Create IDCS OAuth 2.0 Client. A dialog will open for entering oauth2 client details.
    Create IDCS OAuth 2.0 Client option is available only for applications those have platform service URL mentioned. RICS is making use of merch platform service as both the apps are sharing same IDCS tenancy.
    application code RMS
  6. Skip this step if RICS application is not showing up. One of either Step 5 or Step 6 needs to be followed.
    Select a row with application code as RICS. Click on the Actions menu on top left and select Create IDCS OAuth 2.0 Client. A dialog will open for entering oauth2 client details.
    navigator links for retail Home
  7. This dialog takes the following values:
    App Name is 2-100 characters and will be used as the name in IDCS. Provide unique application name.
    Description is a detailed description of the application.
    Scope: <Custom environment-specific scope>
    The scope pattern that is used in the RICS IDCS app creation template is rgbu:rics:<SERVICETYPE>-<ENVIRONMENT> where SERVICETYPE is RICS and ENVIRONMENT is the environment type (STG, PRD, UAT, DEV1, DEV2, and so on).
    For example:
    "scope": "rgbu:rics:RICS-PRD""scope": "rgbu:rics:RICS-STG"
    create idcs oauth client
  8. When the application is created, another dialog will open to show the client ID and client secret of the new application. These values should be copied down to a safe location, as they will only be shown once. Retail Home cannot retrieve the credentials again after the dialog is closed.
    new idcs oauth client
  9. Client ID and Client Secret from previous step will be used for generating access token.
    Sample code for generating Access Token:
    clientId=RICS_TEST_APPID
    clientSecret=998e1e1d-f146-45a5-a9a1-99785e3ebf43
    idcsUrl=https://idcs-234e8f7334564936aa0ed93f2c39e9ca.identity.pint.oc9qadev.com
    scope=rgbu:rics:RICS-STG99
    ec=$(echo -n "$clientId:$clientSecret" | base64 -w 0)
    AccessToken=$(curl -iv \
    -H "Authorization: Basic $ec" \
    -H "Content-Type: application/x-www-form-urlencoded;charset=UTF-8" \
    --request POST $idcsUrl/oauth2/v1/token \
    -d "grant_type=client_credentials&scope=$scope" | grep -o -P '(?<=access_token":").*(?=","token_type)')
    echo $AccessToken
  10. Now service call can be made by passing along the access token generated in previous step.
    Here is sample curl command with Bearer token and rib-ext publisher ping
    ribExtServiceUrl=https://rex.retail.us-phoenix-1.ocs.oc-test.com:443/rgbu-rex-eit-stg99-rics/rib-ext-services-web/resources/publisher/ping
    curl -ivkL --noproxy '*' -H "Authorization: Bearer $AccessToken"  -H "Content-Type: application/xml" -X GET $ri-bExtServiceUrl
    Sample response
    {"message": "ping() was called with input String of: hello"}
  11. Publishing a message using access token.
    Here is sample curl for publishing a message
    ribExtServiceUrl=https://rex.retail.us-phoenix-1.ocs.oc-test.com:443/rgbu-rex-eit-stg99-rics/rib-ext-services-web/resources/publisher/publish
    curl -ivkL --noproxy '*' -H "Authorization: Bearer $AccessToken"  -H "Content-Type: application/xml" -X POST $ribExtServiceUrl --data '<v1:ApplicationMessages xmlns:v1="http://www.oracle.com/retail/integration/rib/ApplicationMessages/v1">
    <v1:ApplicationMessage>
    <v1:family>InvAdjust</v1:family>
    <v1:type>InvAdjustCre</v1:type>
    <v1:payloadXml>&lt;InvAdjustDesc xmlns=&quot;http://www.oracle.com/retail/integration/base/bo/InvAdjustDesc/v1&quot; xmlns:xsi=&quot;http://www.w3.org/2001/XMLSchema-instance&quot;
    xsi:schemaLocation=&quot;http://www.oracle.com/retail/integration/base/bo/InvAdjustDesc/v1
    http://www.oracle.com/retail/integration/base/bo/InvAdjustDesc/v1/InvAdjustDesc.xsd&quot
    ;&gt;&lt;dc_dest_id&gt;DC_ES&lt;/dc_dest_id&gt;&lt;InvAdjustDtl&gt;&lt;item_id&gt;Aline&lt;/item_id&gt;&lt;adjustment_reason_code&gt;stri&lt;/adjustment_reason_code&gt;&lt;unit_qty&gt;22.4&lt;/unit_qty&gt
    ;&lt;transshipment_nbr&gt;ss&lt;/transshipment_nbr&gt;&lt;from_disposition&gt;ss&lt;/from_disposition&gt;&lt;to_disposition&gt;sss&lt;/to_disposition&gt;&lt;from_trouble_code&gt;sss&lt;/from_trouble_code&gt;
    &lt;to_trouble_code&gt;ss&lt;/to_trouble_code&gt;&lt;from_wip_code&gt;aaa&lt;/from_wip_code&gt;&lt;to_wip_code&gt;sss&lt;/to_wip_code&gt;&lt;transaction_code&gt;4&lt;/transaction_code&gt;&lt;user_id&gt;TestUser&lt;/user_id&gt;
    &lt;create_date&gt;1999-10-23T20:27:56.32&lt;/create_date&gt;&lt;po_nbr&gt;PratapOrd96&lt;/po_nbr&gt;&lt;doc_type&gt;P&lt;/doc_type&gt;&lt;aux_reason_code&gt;string&lt;/aux_reason_code&gt;
    &lt;weight&gt;12.4&lt;/weight&gt;&lt;weight_uom&gt;smn;&lt;/weight_uom&gt;&lt;unit_cost&gt;20.4&lt;/unit_cost&gt;&lt;InvAdjustUin&gt;&lt;uin&gt123&lt;/uin&gt;
    &lt;status&gt;4&lt;/status&gt;&lt;/InvAdjustUin&gt;&lt;/InvAdjustDtl&gt;&lt;/InvAdjustDesc&gt;</v1:payloadXml>
    </v1:ApplicationMessage>
    </v1:ApplicationMessages>'
    Sample response
    {"message": "Publish done"}
Retry Pattern for Publishing Service
An application that communicates with elements running in the cloud needs to be sensitive to the transient faults that can occur in this environment. Faults include the momentary loss of network connectivity with components and services, the temporary unavailability of a service (publishing), or timeouts that occur when a service is busy.
These faults are typically self-correcting and, if the action that triggered a fault is repeated after a suitable delay, it's likely to be successful.
Solution
In the cloud, transient faults should be expected and an application should be designed to handle them elegantly and transparently. Doing so minimizes the effects faults can have on business tasks the application is performing. The most common design pattern to address is to introduce a retry mechanism
The diagram below illustrates invoking an operation in a hosted service using a retry mechanism.
Invoking an Operation in a Hosted Service Using a Retry Mechanism
  1. Application invokes operation on hosted service. The request fails, and the service host responds with HTTP response code 500 (internal server error).
  2. Application waits for a short interval and tries again. The request still fails with HTTP response code 500.
  3. Application waits for a longer interval and tries again. The request succeeds with HTTP response code 200 (OK).
If the request is unsuccessful after a predefined number of attempts, the application should treat the fault as an exception and handle it accordingly.
External Application as a Subscriber (rest-app)
For an external application to consume the message from the RIB's JMS on cloud, it has to host the Injector Service. Injector Service is a ReST webservice that is made available as a pluggable jar.
A pluggable jar is provided which contains all the wrapper classes to help in implementing injector service. rib-injector-services-web-<version>.war is the pluggable jar which can be included into the external application deployable file for example, ext-app.ear/lib. Once pluggable jar is added, endpoint for injector service will be exposed as follows:
https://<external-app-host>:<port>/ rib-injector-services-web/resources/injector/inject
Pluggable jar is provided for reference however customer can choose to write their own injector service by adhering to REST service contract detailed in next section.
For information on pluggable jar, see the Client Connector For Oracle Retail Integration Cloud Service 24.0.201.0 (Patch) available on My Oracle Support.
How to implement Injector Service (Service Contract) using ReST
Here is the Rest service contract detail:
  1. Keep the path as Injector/inject.
    @Path("/injector")
  2. Use POST for this service. As the input message object itself has identifier (message type- CRE/MOD) they don't need to use the PUT/PATCH. they can use message type to build the implementation logic.
    @POST
    @Path("/inject")
    @Consumes({MediaType.APPLICATION_XML})
  3. The input would be MediaType.APPLICATION_XML and the structure would be 'ApplicationMessage' object. (file attached for reference).
    <xs:element name="ApplicationMessage">
      <xs:complexType>
        <xs:sequence>
          <xs:element name="family" type="string25"/>
          <xs:element name="type" type="string30"/>
          <xs:element name="businessObjectId" type="string255" minOccurs="0"/>
          <xs:element ref="ApplicationMessageRoutingInfo" minOccurs="0" maxOccurs="unbounded"/>
          <xs:element name="payloadXml" type="xs:string"/>
        </xs:sequence>
      </xs:complexType>
    </xs:element>
  4. Customer can utilize the payload.properties file for validation of message family and type.
  5. Return type should be JSON, see below example:
    String message = "{\"message\": \"Inject successful.\"}";
    return Response.ok(message, MediaType.APPLICATION_JSON).build();
  6. For exception response customer needs to follow the structure of exceptionVO.
How to Secure Injector Service with Oauth2
Injector service exposed by external service should be secured with OAuth2. This chapters covers the key points that should be taken into consideration while protecting the resources exposed by external application.
Prerequisites
  • IDCS should be same as RICS.
  • Use Client Credentials grant type with scope to provide access to resource.
  • Following is the screen shot of a sample IDCS app with scope added
IDCS app with scope
Follow IDCS documentation for detailed instruction on setup.
RIB-EXT Side of Configuration to Point to External Application
Below are the steps to point rib-ext to the correct injector service.
Table 8-2
Category Step Comment
Access RIB Admin GUI
Access the rib admin GUI at https://<external-load-balancer>/rib-ext-admin-gui
Log in with the admin user.
login
Verify Configuration and update
Navigate to Manage Configurations -> System options
Search for and verify the following:
  1. destination.retail.appType: rest-app
  2. Update the value for InjectorService URL (injector.service.endpoint.url). URL should point to inject service provided by external application. (e.g.- https://<host:port>/rib-injector-services-web/resources/injector/inject
  3. Update the value for Ping Service URL (injector.service.endpoint.ping.url). This URL should point to a ping service provided by an external application. (for example - https://<host:port>/rib-injector-services-web/resources/injector/ping).
    Note: This feature allows users to provide their ping URL, as it can be a freeform URL. Previously, it was assumed ping used host:port/injector/ping, causing ping to fail when the systems used its own ping URL. Now, the ping feature in rib-ext relies on the ping implemented on the system. Ping is typically used to test the first-time handshake between the service client and the service provider before sending the actual data over to OIC. The fact that data is moving to OIC tells us that the integration is working fine.
  4. For 3rd party integration where the injector service is hosted on OIC/on-prem, the below system property in JAVA_OPTIONS needs to be added oauth2.url.path.wo.vrc=<context root of injector service>
    Important: context root of injector service is any word in injector service url which can identify service uniquely.
    Eg-
    For the following injector service url https://<external-lb>/ external-injector-services/external/ribinjector/inject.
    Java_option would be
    oauth2.url.path.wo.vrc=ribinjector
  5. Security Policy (injector.service.security.policyname) : policyA
  6. IDCS OAuth Server URL (oauth2.default.authorizationServerUrl): https://<idcs-tenant>/oauth2/v1/token
  7. OAuth2 Token Scope: Update with external application provided scope
Verify Configuration and Update
Update username and password to empty
Navigate to Manage Configurations - > Injector Service
Update details.
  1. Choose "rib-(app)_ws_security_user-name-alias" as Secured User Alias.
  2. Update the Secured User Name with a blank userName.
  3. Update the Secured User Password with a blank password.
  4. Click on Save.
Update Username and Password to Empty
Update ClientID/Secret
Update details
  1. Choose "rib-(app)_oauth2_application_client_user-name-alias" as Secured User Alias.
  2. Update the Secured User Name with clientID.
  3. Update the Secured User Password with clientSecret.
Update ClientID and Secret
Ping Test
Navigate to Manage Configurations -> RIB Service Monitor
  1. Click on ping
  2. It should return success
Ping Test
How to verify provided injector service details are correct
Verify if the provided injector service URL and credentials are correct.
Execute the following curl commands
ClientId=56c7eb72f11b43bb98bf2570fa2353eb
ClientSecret=bb18aa22-4bb4-41d1-9ed4-fea276651e28
IDCSUrl=https://idcs-24e4baae56764e91be371e6a2060d66e.identity.c9dev2.oc9qadev.com
AccessToken=$(curl -i -X POST \ --user $ClientId:$ClientSecret \ -H "Content-Type: applica-tion/x-www-form-urlencoded;charset=UTF-8" \
$IDCSUrl/oauth2/v1/token \ -d "grant_type=client_credentials&scope=urn:opc:idm:__myscopes__" | grep -o -P '(?<=access_token":").*(?=","token_type)')
ribExtServiceUrl=https://rgbu-phx-lbext-351.us.oracle.com/rib-injector-services-web/resources/injector/ping
curl -ivkL --noproxy '*' -H "Authorization: Bearer $AccessToken"  -H "Content-Type: applica-tion/xml" -X GET $ribExtServiceUrl
How to Switch Injector Service App Type at Runtime
RIB-EXT is a rest-app by default for CFS and expects injector service also to be of ReST type. ONLY for egress/migration customers who already have injector service SOAP implementation in GBUCS they should follow these steps to switch from ReST to SOAP based injector calls and vice-versa.
How to Change rib-ext injector-service-app-type from REST to SOAP
  1. Open the rib-ext admin GUI.
  2. Go to Manage Configurations > System Options.
  3. Observe the new property (that is, injector-service-appType). This property was added to allow for switching the injector-service-app-type at runtime.
    By default rib-ext is deployed as rest-app so injector-service-app-type is the default.
    Default rib-ext
  4. Edit injector-service-appType and update this to soap-app. Save the changes.
    Set injector-service-appType to soap-app
  5. Navigate to the Manage Configurations > Injector Service tab. Ensure the injector service URL is correct and ensure it points to correct ext-app injector service. Only host and port can be updated from the UI for a SOAP-based injector service. Ideally, egress migration should take care of migrating a complete injector service URL. This step is only for verification.
    Update rib-ext_ws_security_user-name-alias with correct username/password needed to make inject call.
  6. Setup is ready now. Do a ping test from the RIB ServiceMonitor tab.
How to Change rib-ext injector-service-app-type from SOAP to ReST
  1. Navigate to Manage Configurations > System Options from the admin GUI.
  2. Look for injector-service-appType and change this property from SOAP to ReST.
  3. Save the changes.
    System Options
  4. Navigate to the Injector Service tab. Update the security credentials (rib-ext_ws_security_user-name-alias) as needed. For an injector service secured with Oauth2 (credential grant type) , the rib-ext_ws_security_username_alias credential should be empty and the rib-ext_oauth2_application_client_user-name-alias credential must be updated with the client ID and secret.
  5. Navigate to the Manage Configurations > System Options tab. Ensure the URL (ResT based) is correct and ensure it points to the correct ext-app injector service.
    Injector Service URL
  6. Update the value for the Ping Service URL (injector.service.endpoint.ping.url). This URL should point to a ping service provided by an external application.
    This feature allows users to provide their ping URL. The ping feature in rib-ext relies on the ping implemented on the system. Ping is typically used to test the first-time handshake between the service client and the service provider before sending the actual data to OIC. The fact that data is moving to OIC tells us that the integration is working properly.
  7. Setup is ready now. Do a ping test from RIB Service Monitor tab.
Error Handling
The RIB infrastructure provides a mechanism called RIB error hospital to handle and manage the error messages. When the publishing or subscription of a message fails in the rib-ext for some reason, it lands in error hospital with a reason code. The retry adapters in the rib-ext application are responsible for retrying the messages in error hospital.
Oracle RIB Hospital Administration (RIHA) is a Weblogic application that allows the management of messages in error hospital. Some of the RIHA operations include:
  • Viewing error messages
  • Editing error messages
  • Retrying error messages
  • Stopping error messages
For more information, see the Oracle Retail Integration Bus Hospital Administration Guide.
Monitoring Integration
To monitor live statistics of various components involved in RIB integration system like RIB adapter, error hospital, JMS server, RTG provides a live monitoring application called the Retail Integration Console (RIC).
The RIC is the user interface application designed to provide a unified view of the RTG integration products within the business context of the Oracle Retail applications. It provides near real time statistics regarding the message flows, JMS topics, historical trends of each message family, performance comparisons, and static information like application configuration.
For more information, see the Oracle Retail Integration Console User Guide.
