Enable & Setup View: Rule Groups
The Enable & Setup View, under the Enable & Setup tab, allows you to review who published the rule groups and when they were published. Within this view, you can set up the rule group type and a user-friendly description for the rule group.
Figure 7-10 Enable & Setup View: Rule Groups
Enable & Setup View: Rule Groups - Default Profile Measures
The Enable & Setup view contains the following measures.
Rule Group Manual Filter
This is a checkbox measure that you can select or clear to filter all the views in the workspace by the rule groups selected as manual filters. Only the selected rule groups are available in the workspace. To see all rule groups, all of the rule groups should be cleared. (This is the default behavior).
Rule Group Type
This is a writeable measure used to define the rule group type. Valid values are:
Setup: The rule group is enabled and its purpose is to be available in the Replenishment Setup Rules workspace to set up the supply chain network model.
Parameters: The rule group is enabled and its purpose is to be available in the Replenishment Rules workspace to set up the replenishment method and parameters.
_: Empty space indicates that the rule group is unavailable.
Rule Group User Descr.
Rule Group User Description is an editable measure used to define an alternative description of the rule group. This Rule Group User Description can be set as a Visible Attribute for the Rule Group hierarchy in all the workspaces where the hierarchy is available.
Last Rule Group Publish User ID
This is a calculated measure used to audit the rule group’s Publish Data button. It is populated with the user ID that last ran the Publish Data button.
Last Rule Group Publish Date
This is a calculated measure used to audit the rule group’s Publish Data button. It is populated with the date and time that last ran the Publish Data button.
