Generate Preview
When you use the Generate Preview Publish button, all alterations on the AO Panel are used to create a preview. The preview displays what will happen to the plan if the alterations are made.
This sends all AO Panel alterations to the Science application for the calculation of the preview.
A notification is created when any preview creation completes or fails.
