Capacity Constraint
The Capacity Constraint alert is triggered when a proposed allocation, transfer, or replenishment order would send a quantity of items to a location that exceeds its defined storage capacity. This feature helps prevent sending too much product to a store or warehouse, ensuring merchandise can be processed efficiently and placed on the sales floor rather than getting stuck in a backroom.
When a capacity constraint is violated:
  • An alert is triggered to notify the user.
  • The system will not auto-approve any replenishment or allocation that triggered the alert.
  • Users must manually review the flagged order, where they can choose to modify the quantity or override the constraint to approve the stock movement.
