The Manual Allocation Workflow
The workflow for creating and managing a manual allocation follows a clear, logical progression:
- Select Inventory: Begin by identifying and selecting available inventory from the Inventory Dashboard.
- Define Parameters: Use a guided, multi-step wizard to define the rules of the allocation, including destinations and calculation policies.
- Calculate & Review: Trigger the system to calculate the recommended quantities based on your rules.
- Adjust & Finalize: Review the system's recommendations, make manual overrides as needed, and save the allocation as a "Worksheet" (draft).
- Approve & Export: Formally approve the allocation to lock it from further edits and automatically send it to downstream execution systems like MFCS.
