Run Overview
When you click on the Run Overview tile, the Run Overview table is displayed. The Run Overview table provides information described in the table below.
Table 1-1 Run Overview Table
| Column | Description |
Run Name |
Click the run name to open the run and see the run details. |
| Time-phased Plan Status |
The status of the time phased analysis within that run. Values are Not Applicable, Setup, Preparing Data, Run in Progress, Run Completed Successfully, Partially Successful, Run Failed. |
| Trade-off Status | The status of the trade-off analysis within that run. Values are Not Applicable, Setup, Preparing Data, Run in Progress, Run Completed Successfully, Partially Successful, Run Failed. |
| Truck-scaling Status |
The status of the truck scaling which runs after time-phased planning becomes successful/partially successful. Values are Not Applicable, Setup, Preparing Data, Run in Progress, Run Completed Successfully, Run Failed. |
| Rebalancing Status | The status of the inventory rebalancing within that run. Values are Not Applicable, Setup, Preparing Data, Run in Progress, Run Completed Successfully, Run Failed. |
Replenishment Policy |
Displays the total number of recommendations for replenishment policies at the SKU/location level, with a breakdown by approval status (auto-approved, user-approved, ready for review). |
Rebalancing Transfers |
Displays the total number of rebalancing recommendations at the SKU-origin/destination level, with a breakdown by approval status ( user-approved, ready for review). |
PO/Transfers |
Displays the total number of PO/transfer recommendations with a breakdown by approval status (user-approved, ready for review), as well as a breakdown by recommendation (PO, warehouse-to-store, warehouse-to-warehouse). |
Run Description |
User-provided information. |
Created On |
Date the run was created. |
Created By |
User login name of person creating the run. |
