The Inventory Dashboard
The starting point for all user allocations is the Inventory Dashboard. This screen provides a consolidated view of all inventory that is currently available to be allocated.
Key features of the dashboard include:
  • Unified Inventory View: A central table displays all allocatable items, clearly identifying their source as a PO or Warehouse Stock in the Document Type column.
  • Filtering: You can use powerful filters for Department, Class, and Subclass to quickly find the specific items you need to allocate.
  • Status Tabs: Tabs across the top of the table allow you to view allocations based on their current status:
    • Available: Items that have not yet been included in an allocation.
    • Ready for Review: Allocations that have been saved as a "Worksheet" but are not yet approved.
    • Approved: Allocations that have been finalized and are awaiting export.
    • Approve Failed: The final status of an allocation after the system has attempted to send it to the execution system.
