Preview
A Preview displays a what if scenario, based upon the application of a set of alterations from an AO Panel to the plan.
Generating a Preview is an asynchronous operation. A notification is generated to inform you when it successfully completes or fails.
Some key notifications include:
- Publish Completed. A publish operation has successfully completed.
- Review Ready. A preview has successfully completed its calculations and is ready to be
viewed. The notification is informational. Use the Previews button to reveal a list of previews
to select for viewing.
Figure 1-26 Previews Button
- Failure. Failure notifications are created when something errors during the calculation process. These often include the functionality that when clicked they retry the failed operation again.
A preview is based upon a single product for a set of locations; it opens in a new tab within the IP application.
Their design is similar to a Plan View, with many common features such as:
- Aggregate chart
- Aggregate area with supply chain navigation
- Individual location tables with supply chain navigation
- Promotions
- Edit metrics
Figure 1-27 Preview
