Finalize Runs
Once the run is optimized, if the user wants to send recommendations from another run, the user can select the run and click the Finalize button if the results are satisfactory. Upon finalization, the recommendations from the what-if run replace those from the corresponding batch run in the Manage LPO Recommendation screen.
If there is any conflict, that is, when the new run to be finalized is for same run scope as an existing finalized run, an alert is displayed asking the user to un-finalize the existing finalized run. Users must exercise caution when they un-finalize the existing finalized run, since any approved recommendations will be removed from the export integration views.
