Item Recommendations with Bulk Actions
The Item Recommendations table, shown in the following figure, shows relevant information for each item. The table actions are used to select multiple items for a price change operation such as accept, reject, override, or add a promotion, markdown, or regular price change. A user can also move the effective start/end dates for a promotion/markdown. Once you make the necessary price or date changes, you can click Recalculate, which updates all the projected metrics for the modified items. When you are satisfied with the recommendations, you can perform recommendation status operations such as Review, Submit, or Approve. Submit or Approve not only send recommendation to the Export Interface, but when integrated with RPCS, also push recommendations in corresponding statuses through a web service.
For details, see Appendix: Promotion and Markdown Run Overview and Appendix: Regular Manage LPO Recommendation.
Table 7-1 Item Recommendations Actions
| Field | Description |
Action |
Click the Note icon to add any text comment to the recommendation. The Flag icon is used to flag a recommendation. These two icons are also displayed in the Review Exception screen. |
Actions |
Price or Date override operation for the item is successful. Recalculate icon is added to denote that the recalculation of projected metrics is pending. |
Actions |
Price or Date override operation for the item is not successful. You must either modify the rounding criteria/tolerance used or modify the pricing logic (percentage versus price point). |
Action - Wrap Text |
Wrap the longer texts for better viewability. |
Action - DD-MM-YY |
When clicked, all the dates in the table are displayed in DD-MMM-YY format. |
Table 7-2 Item Recommendations Status
| Status | Description |
| Ready for Review | The optimization process is complete, and the run status and item recommendations are ready for review. |
| Reviewed | The analyst finished reviewing the price recommendations and changes the item recommendation status to Reviewed so that it is sent to the buyer for approvals. |
| Submitted | The recommendations have been reviewed and submitted or approved for execution. The recommendations are ready for export to other applications. |
| Approved | The recommendations have been reviewed and approved for execution. The recommendations are ready for export to other applications. |
| Rejected | The recommendations have been reviewed and rejected for execution. |
| Export Success | The export of recommendations to other systems have been successful. |
| Export Failed | The export of recommendations to other systems has failed. |
| Taken | The recommendations have been approved by an external system (for example, RPCS) and sent to LPO. |
| Auto Approved | The recommendations have been auto approved for execution as they have met the auto approval criteria. |
