F Appendix: Promotion and Markdown - Manage LPO Recommendations
This table provides information about table columns and calculations for Promotion and Markdown Optimization recommendations.
Column Heading Default (Y/N) Definition DB Reference / Calculation
Flag Y Users can flag the recommendation for further review. PRO_RUN_RECOM_OPT_RESULT.FCST_REVIEW_CODE
Notes Y Users can enter any comment for the recommendation. For example, Additional Budget received so overriding to a deeper markdown PRO_RUN_RECOM_OPT_RESULT.FCST_NOTE
Ovrd Status Y Shows whether the item has any pending recalculate. It shows which user requested it. PRO_RUN_RECOM_OPT_RESULT.CHANGED_BY_USER
Ext Code, Name, Descr of - Item / Division / Group / Department / Class / Sub Class / Style / Style Color Y Product Hierarchy CONCAT(RSE_PROD_HIER.PROD_EXT_CODE,'-',RSE_PROD_HIER.NAME)Based on RSE_PROD_HIER.HIER_LEVEL_ID
Item Descr Y Item description, external code, and name separated in different columns. RSE_PROD_HIER.DESCRRSE_PROD_HIER.HIER_LEVEL_ID=8
Brand Name Y   RSE_PROD_GRP.NAME
Price Zone Y Price zone of the item recommendation. Corresponds to the run setup level.
RSE_PRICE_ZONE and RSE_PRICE_ZONE_GRP
Chain Ext Code/Name/Descr > Area > Region > District > Location Ext Code / Name / Descr Y Location Hierarchy. N/A with Price Zones. RSE_LOC_HIER_DH
Rec Status Y Recommendation status of the item, which says Ready for Review> Reviewed > Approved/Submitted/Taken > Export Failed PRO_RUN_RECOM_OPT_RESULT.RECOMMENDATION_STATUS_IDJoin With PRO_RECOMMENDATION_STATUS on ID to get UI_NAME.
Season Y
Season. For example, Fall 2024 Merchandise
PRO_SEASON.NAME
Company - Dynamic level (clean up) Y Location of the item recommendation. (For example, Region, Channel, and so on). Corresponds to the run location setup level. Will be chain when using price zones. PRO_DB_PARAMETER_VW; #PRO_LOC_HIER_PROCESSING_LVL = 1 (RSE_HIER_LVL) RSE_LOC_HIER
Tkt Price Y Ticket Price of the item. Reflects TRAN TYPE 0, 4, 8. Rolled up from leaf node levels (for example, SKU-STORE) using Most Common Value PRO_RUN_RECOM_OPT_RESULT.CURRENT_PRICE
Reg Price Y Regular Price of the item. Reflects TRAN TYPE 0, 4. Rolled up from leaf node levels (for example, SKU-STORE) using Most Common Value PRO_RUN_RECOM_OPT_RESULT.LAST_REGULAR_PRICE
Orig Price Y Original Price of the item. Reflects TRAN TYPE 0. Rolled up from leaf node levels (for example, SKU-STORE) using Most Common Value PRO_RUN_RECOM_OPT_RESULT.REGULAR_PRICE
Eff Price Y Effective Price of the item - it will reflect either the recommended or the overridden/user added price. If the recommendation is rejected, then it will reflect the ticket price of the item. Determined during run-time and displayed in UI.
Eff Rec Type Y Effective Recommendation Type of the item. It will be recommended, or the overridden/user added or rejected action. Determined during run-time and displayed in UI.
Eff Start Dt Y Effective start date of the recommendation. Reflect user date override as well. PRO_RUN_RECOM_OPT_RESULT.EFF_START_DT
Eff End Dt Y Effective end date of the recommendation. Not applicable for Markdowns. Reflect user date override as well. PRO_RUN_RECOM_OPT_RESULT.EFF_END_DT
Eff % off Tkt Y Effective Price as % off of Ticket Price. Determined during run-time and displayed in UI.
Eff % off Orig Y Effective Price as % off of Original Price. Determined during run-time and displayed in UI.
Eff % off Regular Y Effective Price as % off of Regular Price. Determined during run-time and displayed in UI.
Rec Price Y Recommended Price of the Item PRO_RUN_RECOM_OPT_RESULT.RECOM_PRICE
Rec Type Y Recommendation Type of the Item. Markdown, Promotion, No Recommendation, Non-forecasted PRO_RUN_RECOM_OPT_RESULT.PRICE_RECOM_TYPE_ID Join with PRO_PRICE_RECOM_TYPE on ID to get DESCR
Rec % off Tkt Y Recommended Price as % off of the Ticket Price. PRO_RUN_RECOM_OPT_RESULT
Rec % off Orig Y Recommended Price as % off of the Original Price. PRO_RUN_RECOM_OPT_RESULT
Mkdn Cnt Y Markdown Number. If the item is marked down, this number will go up by 1. PRO_RUN_RECOM_OPT_RESULT.MKDN_COUNT
Promo Cnt Y Promotion Number. If the item is promoted, this number will go up by 1. PRO_RUN_RECOM_OPT_RESULT.PROMO_COUNT
Price Rung Y Rungs that are defined in the rules table for rule name PRO_RUNG_TIER_DISC_PCT. It is calculated with respect to the basis defined in PRO_DISC_TIER_BASIS. PRO_RUN_RECOM_OPT_RESULT.DISC_TIER
Proj Sls Units Y Projected Sales Units for the Effective Week, including any applied overrides. PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_FORECASTED_SALES
Proj Sls Rev Y Projected Sales Revenue for the Effective Week. PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_REVENUE
Proj GM Y Projected Gross Margin $ for the Effective Week, including any applied overrides. PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_GROSS_MARGIN
Proj Sls Units (Last Act to EW) Y Projected Sales Units from the Last Actual Week (or Processing Week) and until the Effective Week, including any applied overrides. It does not include the Last Actual Week and Effective Week. PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_FORECASTED_SALES
Proj Inv Beg of EW Y Projected inventory position at the beginning of the Effective Week, including any applied overrides. PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_FORECASTED_SALES+OPTIMAL_REMAINING_INVENTORYPRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_OPT_SALES_QTY
Last Act Inv Y Inventory for the Last Actual Week (or Processing Week). It is the sum of all inventory components that are configured to be used for optimization. PRO_RUN_RECOM_OPT_RESULT.INV_QTY_LAD
Total Buy Y It is sum of Cumulative Sls Units and the Last Act Inv. Cumulative Sls Units is calculated from the first receipt date. PRO_RUN_RECOM_OPT_RESULT.INITIAL_INVENTORY
Promo Bdgt Used Y This is calculated as the Proj Sls Units * (ticket price - recom price). PRO_RUN_RECOM_OPT_RESULT.PROMO_BUDGET_USED
Mkdn Bdgt Used Y This is calculated as the Proj Inv Beg of EW * (ticket price - recom price) PRO_RUN_RECOM_OPT_RESULT.MKDN_BUDGET_USED
Start Dt Y Start date of the Item. For example, 2% ST or 3 weeks from first receipt date. PRO_RUN_RECOM_OPT_RESULT.MODEL_START_DT
Exit Dt Y Exit date of the item. PRO_RUN_RECOM_OPT_RESULT.EXIT_DT
Run Id and Name Y ID of optimization run generating rec. CONCAT(PRO_RUN_HDR.ID,'-',PRO_RUN_HDR.NAME)
Optimization Date Y Date of optimization run. PRO_RUN_HDR.LAST_EXECUTION_DATE
Recalculation Date Y Date when the item is recalculated. PRO_RUN_RECOM_OPT_RESULT.RECALCULATE_DT
Recalculation User Y User who last requested the recalculate. PRO_RUN_RECOM_OPT_RESULT.RECALCULATE_BY_USER
Exported On Date Y Date when the item is Approved. PRO_RUN_RECOM_OPT_RESULT.EXPORTED_ON_DT
Approved By User Y User who approved the recommendation. PRO_RUN_RECOM_OPT_RESULT.EXPORTED_BY_USER
Net Sales Units (Last Week) Y Number of product units sold in the last completed week. PRO_RUN_RECOM_DENORMALIZE.SLS_QTY_LAST_WEEK
Curr Sls Units Y Projected Sales Units for the Effective Week at Current Price. PRO_RUN_RECOM_OPT_RESULT.CURRENT_FORECASTED_SALES
Curr Sls Rev Y Projected Sales Revenue for the Effective Week at Current Price. PRO_RUN_RECOM_OPT_RESULT.CURRENT_REVENUE
Curr GM Y Projected Sales Margin for the Effective Week at Current Price. PRO_RUN_RECOM_OPT_RESULT.CURRENT_GROSS_MARGIN
Ovrd Price N Overridden price for the item. PRO_RUN_RECOM_OPT_RESULT.USR_OVRD_RECOM_PRICE
Ovrd Price Type N Override price type for the item. PRO_RUN_RECOM_OPT_RESULT.USR_OVRD_PRICE_RECOM_TYPE_ID JOIN WITHPRO_PRICE_RECOM_TYPE ON ID to get DESCR
Rec Accepted? N Y or No flag to denote whether recommendation was accepted as is or not. PRO_RUN_RECOM_OPT_RESULT.ACCEPTED_FLG
Proj Inv End of EW N Projected inventory at the end of the effective week, including any applied overrides. PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_REMAINING_INVENTORY
Final Ship Dt N Denotes the calculated final ship date of the item. Last inventory change date that is older than x weeks (configuration) is assigned as the final ship date for the item PRO_RUN_RECOM_OPT_RESULT.FINAL_SHIP_DT
Proj Inv EOL N Projected inventory at end of the life, including any applied overrides. PRO_RUN_RECOM_OPT_RESULT.PROJ_OPT_EOL_INV
Proj ST EOL N Projected sell through at end of life, including any applied overrides. 1-(PRO_RUN_RECOM_OPT_RESULT.PROJ_OPT_EOL_INV / PRO_RUN_RECOM_OPT_RESULT.INITIAL_INVENTORY)
Curr Proj Inv EOL N Projected inventory with current price at end of life, including any applied overrides. PRO_RUN_RECOM_OPT_RESULT.PROJ_CURR_EOL_INV
Curr Proj ST EOL N
Projected sell through at end of life with current price, including any applied overrides.
1-(PRO_RUN_RECOM_OPT_RESULT.PROJ_CURR_EOL_INV / PRO_RUN_RECOM_OPT_RESULT.INITIAL_INVENTORY)
Proj Sls Units EOL N Total projected sales units at end of life, including any applied overrides. It is calculated as the sum of cumulative sales units until the last actual week and projected sales units for the remainder of the life at the optimal price path, including any applied overrides. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_SLS_QTY + PRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_OPT_SALES_QTY
Proj Rev EOL N Total projected revenue at end of life, including any applied overrides. It is calculated as the sum of cumulative sales revenue until the last actual week and projected sales revenue for the remainder of the life at the optimal price path. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_SLS_AMT + PRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_OPT_REVENUE
Proj GM EOL N Total projected gross margin at end of life, including any applied overrides. It is calculated as the sum of cumulative sales gross margin until the last actual week and projected sales gross margin for the remainder of the life at the optimal price path. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_GMARGING+ PRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_OPT_GMARGIN
Curr Proj Sls Units EOL N Total projected sales units at end of life with current price, including any applied overrides. It is calculated as the sum of cumulative sales units until the last actual week and projected sales units for the remainder of the life at the current ticket price. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_SLS_QTY + PRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_CURR_SALES_QTY
Curr Proj Rev EOL N Total projected revenue at end of life with current price, including any applied overrides. It is calculated as the sum of cumulative sales revenue until the last actual week and projected sales revenue for the remainder of the life at the current ticket price. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_SLS_AMT + PRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_CURR_REVENUE
Curr Proj GM EOL N Total projected gross margin at end of life with current price, including any applied overrides. It is calculated as the sum of cumulative sales gross margin until the last actual week and projected sales gross margin for the remainder of the life at the current ticket price. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_GMARGING+ PRO_RUN_RECOM_OPT_RESULT.TOT_PROJ_CURR_GMARGIN
Sls Units T/D N Net Sales Units till last loaded week. PRO_RUN_RECOM_DENORMALIZE.CUM_TOT_SLS_QTY
Sls Units 1W Ago N Net Sales Units 1 week ago. PRO_RUN_RECOM_DENORMALIZE.SLS_QTY_LAST_WEEK
Sls Units 2W Ago
N
Net Sales Units 2 week ago.
PRO_RUN_RECOM_DENORMALIZE.SLS_QTY_2_AGO
Sls Units 3W Ago
N
Net Sales Units 3 week ago.
PRO_RUN_RECOM_DENORMALIZE.SLS_QTY_3_AGO
Sls Amt 4W Ago
N
Net Sls Amount/Revenue 4 weeks ago.
PRO_RUN_RECOM_DENORMALIZE.SLS_AMT_4_AGO
Sls Amt T/D
N
Net Sls Amount/Revenue till last loaded week.
Sls Amt 1W Ago
N
Net Sls Amount/Revenue 1 week ago.
PRO_RUN_RECOM_DENORMALIZE.SLS_AMT_LAST_WEEK
Sls Amt 2W Ago
N
Net Sls Amount/Revenue 2 weeks ago.
PRO_RUN_RECOM_DENORMALIZE.SLS_AMT_2_AGO
Sls Amt 3W Ago
N
Net Sls Amount/Revenue 3 weeks ago.
PRO_RUN_RECOM_DENORMALIZE.SLS_AMT_3_AGO
Sls Amt 4W Ago
N
GM T/D
N
Net Gross Margin till last loaded week.
GM 1W Ago
N
Net Gross Margin 1 week ago.
PRO_RUN_RECOM_DENORMALIZE.GMARGING_LAST_WEEK
GM 2W Ago
N
Net Gross Margin 2 weeks ago.
PRO_RUN_RECOM_DENORMALIZE.GMARGING_AMT_2_AGO
GM 3W Ago
N
Net Gross Margin 3 weeks ago.
PRO_RUN_RECOM_DENORMALIZE.GMARGING_AMT_3_AGO
GM 4W Ago
N
Net Gross Margin 4 weeks ago.
PRO_RUN_RECOM_DENORMALIZE.GMARGING_AMT_4_AGO
Target ST EOL
N
Business rule - percentage of sell-through for each product at end of clearance season.
PRO_RUN_RECOM_OPT_RESULT.TARGET_ST_PCT
Max Competitor Price N Max competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MAX_COMPETITOR_PRICE
Min Competitor Price N Min competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MIN_COMPETITOR_PRICE
Avg Competitor Price N Average competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.AVG_COMPETITOR_PRICE
Most Common Competitor Price N Most common competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MCV_COMPETITOR_PRICE
ProdAttrValue1 - Prod AttrValue 5
N
Product attributes selected by the user in the user filter. For example, Brand.
RSE_PROD_ATTR
Currency Attribute 1 - 30
Y
User Defined Attribute of Currency Type.
Flex Fact (W_RTL_FLEX_FACT)
Date Attribute 1 - 15
Y
User Defined Attribute of Date type.
Number Attribute 1 - 40
Y
User Defined Attribute of Number Type.
Percentage Attribute 1 - 15
Y
User Defined Attribute of percentage Type.
Text Attribute 1 - 30
Y
User Defined Attribute of Text Type.
