C Appendix: Regular - Pricing Optimization Rules
This table provides information about the Regular Pricing Optimization rules.
Rule Sub Category Rule Name Rule Description Rule Datatype Requires Forecast?
Pack Pricing RPO_SIMPLE_PACK_SELLABLE Total price of the simple pack (multiple units of the same item) should be lower than the total price of the single item but at least this fixed value. NUMBER N/F
RPO_SIMPLE_PACK_SELLABLE_PCT Total price of the simple pack (multiple units of the same item) should be lower than the total price of the single item but at least this percentage value of the total price of the single item. PERCENTAGE N/F
RPO_COMPLEX_PACK_SELLABLE Total price of the complex pack should be lower the total price of its components by at least this fixed value. NUMBER N/F
RPO_COMPLEX_PACK_SELLABLE_PCT Total price of the complex pack should be lower than the total price of its components by at least this percentage value of the total price of its components. PERCENTAGE N/F
Competitor and CPI RPO_COMP_MATCH_HIGHER Price of the item needs to be higher than the competitor price by this value. NUMBER N/F
RPO_COMP_MATCH_HIGHER_PCT Price of the item will need to be this many percentage points higher than the competitor price. PERCENTAGE N/F
RPO_COMP_MATCH_LOWER Price of the item needs to be lower than the competitor price by this value. NUMBER N/F
RPO_COMP_MATCH_LOWER_PCT Price of the item will need to be this many percentage points lower than the competitor price. PERCENTAGE N/F
RPO_CPI_PCT_CHANGE_MAX Consumer Price Index will need to be within this maximum percentage tolerance of a base historical CPI (e.g. previous year). PERCENTAGE F
RPO_CPI_PCT_CHANGE_MIN Consumer Price Index will need to be within this minimum percentage tolerance of a base historical CPI (e.g. previous year). PERCENTAGE F
Cost Change RPO_COST_CHANGE If the cost of the item increases/decreases by this amount, regular price for the item must increase or decrease accordingly. NUMBER N/F
RPO_COST_PCT_CHANGE Percentage of the cost change passed on to the regular price for the item. 100% means the regular price of the item must reflect the entire cost increase/decrease PERCENTAGE N/F
Goal RPO_OPTIMIZATION_OBJECTIVE Optimization goal for pricing. Required for running optimization. RULE_VALUE should be set as one of the following: MAX_MARGIN, MAX_REVENUE, MAX_VOLUME. TEXT F
Inter-Item RPO_INTER_ITEM_DIFF_MAX Products in Set A need a price less or equal than this value compared to items in Set B. NUMBER N/F
RPO_INTER_ITEM_DIFF_MAX_PCT Products in Set A need a price percentage less or equal than this value compared to items in Set B. PERCENTAGE N/F
RPO_INTER_ITEM_DIFF_MIN Products in Set A need a price greater or equal than this value compared to items in Set B. NUMBER N/F
RPO_INTER_ITEM_DIFF_MIN_PCT Products in Set A need a price percentage greater or equal than this value compared to items in Set B. PERCENTAGE N/F
Inter-Loc/PZ RPO_INTER_LOC_DIFF_MAX Regular price for the same product in location A need a price less or equal by this value compared to same product in location B. NUMBER N/F
RPO_INTER_LOC_DIFF_MAX_PCT Regular price for the same product in location A need a percentage price less or equal by this value compared to same product in location B. PERCENTAGE N/F
RPO_INTER_LOC_DIFF_MIN Regular price for the same product in location A need a price greater or equal by this value compared to same product in location B. NUMBER N/F
RPO_INTER_LOC_DIFF_MIN_PCT Regular price for the same product in location A need a percentage price greater or equal by this value compared to same product in location B. PERCENTAGE N/F
Margin for Item RPO_LIST_MARGIN_ITEM_MAX List Margin for each item in the group/product hierarchy node needs to be less or equal than this value. NUMBER N/F
RPO_LIST_MARGIN_ITEM_MAX_PCT List Margin for each item in the group/product hierarchy node needs to be less or equal than this percentage value. PERCENTAGE N/F
RPO_LIST_MARGIN_ITEM_MIN List Margin for each item in the group/product hierarchy node needs to be greater or equal than this value. NUMBER N/F
RPO_LIST_MARGIN_ITEM_MIN_PCT List Margin for each item in the group/product hierarchy node needs to be greater or equal than this percentage value. PERCENTAGE N/F
RPO_MARGIN_ITEM_MAX Margin for each item in the group/product hierarchy node needs to be less or equal than this value. NUMBER F
RPO_MARGIN_ITEM_MAX_PCT Margin for each item in the group/product hierarchy node needs to be less or equal than this percentage value. PERCENTAGE F
RPO_MARGIN_ITEM_MIN Margin for each item in the group/product hierarchy node needs to be greater or equal than this value. NUMBER F
RPO_MARGIN_ITEM_MIN_PCT Margin for each item in the group/product hierarchy node needs to be greater or equal than this percentage value. PERCENTAGE F
RPO_MARGIN_ITEM_PCT_CHANGE_MAX Margin for each item in the group/product hierarchy node needs to have a maximum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
RPO_MARGIN_ITEM_PCT_CHANGE_MIN Margin for each item in the group/product hierarchy node needs to have a minimum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
Margin for Group RPO_LIST_MARGIN_MAX List Margin for group of items needs to be less or equal than this value. NUMBER N/F
RPO_LIST_MARGIN_MAX_PCT List Margin for group of items needs to be less or equal than this percentage value. PERCENTAGE N/F
RPO_LIST_MARGIN_MIN List Margin for group of items needs to be greater or equal than this value. NUMBER N/F
RPO_LIST_MARGIN_MIN_PCT List Margin for group of items needs to be greater or equal than this percentage value. PERCENTAGE N/F
RPO_MARGIN_MAX Margin for group of items needs to be less or equal than this value. PERCENTAGE F
RPO_MARGIN_MAX_PCT Margin for group of items needs to be less or equal than this percentage value. PERCENTAGE F
RPO_MARGIN_MIN Margin for group of items needs to be greater or equal than this value. NUMBER F
RPO_MARGIN_MIN_PCT Margin for group of items needs to be greater or equal than this percentage value. NUMBER F
RPO_MARGIN_PCT_CHANGE_MAX Margin for group of items needs to have a maximum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
RPO_MARGIN_PCT_CHANGE_MIN Margin for group of items needs to have a minimum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
Price Range RPO_LAST_REG_PRICE_MAX_CHANGE Item needs to have a maximum price change equal to this value compared to the last known regular price of the same item or a similar item. NUMBER N/F
RPO_LAST_REG_PRICE_MAX_PCT_CHANGE Item needs to have maximum percentage price changes equal to this value compared to the last known regular price of the same item or a similar item. PERCENTAGE N/F
RPO_LAST_REG_PRICE_MIN_CHANGE Item needs to have minimum price changes equal to this value compared to the last known regular price of the same item or a similar item. NUMBER N/F
RPO_LAST_REG_PRICE_MIN_PCT_CHANGE Item needs to have a minimum percentage price change equal to this value compared to the last known regular price of the same item or a similar item. PERCENTAGE N/F
RPO_PRICE_MAX Price of item needs to be less or equal than this value. NUMBER N/F
RPO_PRICE_MIN Price of item needs to be greater or equal than this value. NUMBER N/F
Pricing Group RPO_WTHN_GROUP_AVERAGE_TOLERANCE Price for the products within the group must be the average current regular price of the group, subject to tolerance equal to this value. To set equal to the average, tolerance should be set to 0. NUMBER N/F
RPO_WTHN_GROUP_AVERAGE_TOLERANCE_PCT Price for the products within the group must be the average current regular price of the group, subject to tolerance as percentage of the average price. To set equal to the average, tolerance should be set to 0. PERCENTAGE N/F
RPO_WTHN_GROUP_DIFF_TOLERANCE Products within a single group need to have similar price with a tolerance equal to this value. To set equality within the group, tolerance should be set to 0. NUMBER N/F
RPO_WTHN_GROUP_DIFF_TOLERANCE_PCT Products within a single group need to have similar price with a percentage tolerance equal to this value. To set equality within the group, tolerance should be set to 0. PERCENTAGE N/F
RPO_WTHN_GROUP_HIGHEST_TOLERANCE Price for the products within the group must be the highest current regular price of the group, subject to tolerance equal to this value. To set equal to the highest, tolerance should be set to 0. NUMBER N/F
RPO_WTHN_GROUP_HIGHEST_TOLERANCE_PCT Price for the products within the group must be the highest current regular price of the group, subject to tolerance as percentage of the highest price. To set equal to the highest, tolerance should be set to 0. PERCENTAGE N/F
RPO_WTHN_GROUP_LOWEST_TOLERANCE Price for the products within the group must be the lowest current regular price of the group, subject to tolerance equal to this value. To set equal to the lowest, tolerance should be set to 0. NUMBER N/F
RPO_WTHN_GROUP_LOWEST_TOLERANCE_PCT Price for the products within the group must be the lowest current regular price of the group, subject to tolerance as percentage of the lowest price. To set equal to the lowest, tolerance should be set to 0. PERCENTAGE N/F
RPO_WTHN_ZONE_DIFF_TOLERANCE Locations within a single group need to have similar prices, subject to a tolerance level equal to this amount. Equality within the group, tolerance should be set to 0. NUMBER N/F
RPO_WTHN_ZONE_DIFF_TOLERANCE_PCT Locations within a single group need to have similar prices, subject to a tolerance percentage level equal to this amount. Equality within the group, tolerance should be set to 0. PERCENTAGE N/F
Revenue for Item RPO_REVENUE_ITEM_MAX Revenue for each item in the group/product hierarchy node needs to be less or equal than this value. NUMBER F
RPO_REVENUE_ITEM_MIN Revenue for each item in the group/product hierarchy node needs to be greater or equal than this value. NUMBER F
RPO_REVENUE_ITEM_PCT_CHANGE_MAX Revenue for each item in the group/product hierarchy node needs to have a maximum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
RPO_REVENUE_ITEM_PCT_CHANGE_MIN Revenue for each item in the group/product hierarchy node needs to have a minimum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
Revenue for Group RPO_REVENUE_MAX Revenue for group of items needs to be less or equal than this value. NUMBER F
RPO_REVENUE_MIN Revenue for group of items needs to be greater or equal than this value. NUMBER F
RPO_REVENUE_PCT_CHANGE_MAX Revenue for group of items needs to have a maximum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
RPO_REVENUE_PCT_CHANGE_MIN Revenue for group of items needs to have a minimum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
Volume for Item RPO_VOLUME_ITEM_MAX Volume for each item in the group/product hierarchy node to be less or equal than this value. INTEGER F
RPO_VOLUME_ITEM_MIN Volume for each item in the group/product hierarchy node needs to be greater or equal than this value. INTEGER F
RPO_VOLUME_ITEM_PCT_CHANGE_MAX Volume for each item in the group/product hierarchy node needs to have a maximum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
RPO_VOLUME_ITEM_PCT_CHANGE_MIN Volume for each item in the group/product hierarchy node needs to have a minimum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
Volume for Group RPO_VOLUME_MAX Volume for group of items needs to be less or equal than this value. INTEGER F
RPO_VOLUME_MIN Volume for group of items needs to be greater or equal than this value. INTEGER F
RPO_VOLUME_PCT_CHANGE_MAX Volume for group of items needs to have a maximum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
RPO_VOLUME_PCT_CHANGE_MIN Volume for group of items needs to have a minimum percentage increase compared to base period (e.g. last year, last quarter). PERCENTAGE F
