H Appendix: Promotion and Markdown - Review Forecast
This table provides information about table columns and calculations for Promotion and Markdown Review Forecasts.
Column Heading Default (Y/N) Definition DB Reference / Calculation
Class / Subclass / Style / Color / Customer Segment
Y
Product Hierarchy (Depending on the Filter)
CONCAT(RSE_PROD_HIER.PROD_EXT_CODE,'-',RSE_PROD_HIER.NAME)Based on RSE_PROD_HIER.HIER_LEVEL_ID
Price Zone
Y
Price zone of the item recommendation. Corresponds to the run setup level.
RSE_PRICE_ZONE and RSE_PRICE_ZONE_GRP
Company (Dynamic Level)
Y
Location of the item recommendation. (For example, Region, Channel, and so on). Corresponds to the run location setup level. Will be chain when using price zones. PRO_DB_PARAMETER_VW; #PRO_LOC_HIER_PROCESSING_LVL = 1 (RSE_HIER_LVL)
RSE_LOC_HIER
Week Ending Date Y
PRO_RUN_RECOM_OPT_RESULT.CAL_HIER_ID JOIN WITHRSE_CAL_HIER ON ID to get CAL_TO_DT
Current Gross Margin Y Gross Margin generated by the product using the current price. CURRENT_GROSS_MARGIN
Current Forecasted Demand Y Forecast demand calculated by the optimization process using the current price. CURRENT_FORECASTED_DEMAND
Current Remaining Inventory Y End of week inventory using the CURRENT_FORECASTED_SALES. CURRENT_REMAINING_INVENTORY
Current Forecasted Sales Y Forecast sales calculated by the optimization process using the current price. CURRENT_FORECASTED_SALES
Proj Inv End of Wk
Y
Projected inventory at the end of the effective week, including any applied overrides.
PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_REMAINING_INVENTORY
Proj Sls Units
Y
Projected Sales Units for the Effective Week, including any applied overrides.
PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_FORECASTED_SALES
Proj Sls Rev
Y
Projected Sales Revenue for the Effective Week, including any applied overrides.
PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_REVENUE
Tkt Price
Y
Ticket Price of the item. Reflects TRAN TYPE 0, 4, 8. Rolled up from leaf node levels (For example, SKU-STORE) using Most Common Value.
PRO_RUN_RECOM_OPT_RESULT.CURRENT_PRICE
Proj Tkt Price
Y
Projected ticket Price of the item for the Effective Week. Reflects TRAN TYPE 0, 4, 8. Rolled up from leaf node levels (For example, SKU-STORE) using Most Common Value.
Proj Sls Price
Y
Projected Sales Price for the Effective Week, including any applied overrides.
PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_PRICE
Base Sales Units
Y
The expected sales volume for the effective week after adjusting the base demand for seasonality effects.
BASE_DEMAND * SEASONALITY_INDEX
Sales Units from Price Changes
Y
The change in unit sales driven by applying the optimal price effect to the base demand.
Base Sales Units * OPTIMAL_PRICE_EFFECT - BASE_DEMAND
Sales Units from Planned Events
Y
The change in unit sales due to planned promotional activities compared to the base demand.
Base Sales Units * PLANNED_PROMOTION_LIFT - BASE_DEMAND
Cumulative Sales Units
Y
The running total of Proj Sls Units from the last actual date.
Cumulative Sum of PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_FORECASTED_SALES
Demand Units at Full Price
Y
Units expected to be sold at the full price.
Base Demand
Y
The estimated sales volume before applying any promotional, markdown `or seasonal adjustments.
BASE_DEMAND
Item Count
Y
The total number of items included in the product hierarchy. For example, it is 1 if product hierarchy is style - color.
No Recom Item Count
Y
The number of items for which no new price recommendation was generated.
Under 30%
Y
Count of Promotion/Markdown - Under 30%.
(PRO_RUN_RECOM_OPT_RESULT.CURRENT_PRICE-PRO_RUN_RECOM_OPT_RESULT.OPTIMAL_PRICE)/PRO_RUN_RECOM_OPT_RESULT.CURRENT_PRICE
30%-50%
Y
Count of Promotion/Markdown - 30% to 50%
Over 50%
Y
Count of Promotion/Markdown - Over 50%..
Week Start Date
Y
Promotion/Markdown event start date.
PRO_RUN_RECOM_OPT_RESULT.CAL_HIER_IDJOIN WITHRSE_CAL_HIER ON ID to get CAL_FROM_DT
