10 Common UI Components
This chapter describes the common UI components.
Icons
The following icons are used in the user interface. Certain icons have slightly different definitions, depending on the context.
Table 10-1 Icons
Icon Description
copy a run
Copy a run.
create
Create. Create a row. Create a run.
detach
Detach
delete
Delete. The object deleted depends on the context.
edit
Edit. Change status.
embedded help
Embedded help.
export
Export to Excel. Export all.
freeze
Freeze.
go to top
Go to top.
go up
Go up.
go to bottom
Go to bottom.
go down
Go down.
move
Move selected item to another list.
Progress indicator. The indicator changes mode when the application is processing data.
query by example
Filter/Query by example.
refresh
Refresh.
remove all items
Remove all items form list.
remove selected items
Remove selected items from list.
required
Required.
select date
Select date.
wrap
Wrap.
Buttons
Buttons are used to perform certain actions and for navigation.
Table 10-2 Buttons
Button Description
Action Provides access to the following actions: Save, Optimize, Re-Optimize, Reviewed, Save, Recalculate, and Submit
Back
Used to return to the previous train stop.
Cancel
Used to close a dialog box without making a selection.
Clear Selection
Clears the selected rows list.
Next
Moves to the next train stop.
Save
Saves the existing settings.
Select All
In Business Rules - Pricing Groups, selects the entire set of rows displayed.
Accept All
In Results, accepts all the price recommendations.
Pull-Down Menus
The user interface has two pull-down menus that provide access to a variety of functionality.
The Actions pull-down menu provides functionality that you use to manipulate the application data.
Action Description
Create Run
In Run Overview, takes you to the Optimization Setup train stop.
Copy Run
In Run Overview, used to create a duplicate of an existing run.
Delete Run
In Run Overview, used to delete a run.
Export to Excel
Used to export the set of rows displayed to Excel.
Add
In Business Rules-Pricing Groups, used to add data.
Edit
In Business Rules-Pricing Groups, used to edit data.
Delete
In Business Rules-Pricing Groups, used to delete data.
Create
In Fixture and Product Data, used to create.
The View pull-down menu can be used to adjust how the display is organized.
Figure 10-2 View Menu
This image shows the view pull-down menu.
The options provided are:
Action Description
Manage Columns Provides the ability to choose/hide columns and reorder them.
Computed Columns Displayed only for Recommendations table, provides the ability to create custom columns with user defined computations.
Detach Maximizes the table to fit your browser.
Sort Provides the ability to specify up to three columns to sort the data in ascending or descending order for each column.
Query by Example (Filter Options)
Query by Example can be turned off or on by clicking the option in View menu or by clicking the Query by Example icon in the table toolbar. Clicking the icon displays empty text boxes over the table. You can filter the table data based on the filter on each column.
Manage Columns
The Manage Columns feature in the View menu of the LPO Manage Recommendations, LPO Run Overview, and LPO What-if Results screens lets you save, name, and manage multiple custom column configurations (views). This allows you to easily switch between different column setups for exporting, reporting, or analysis, without needing to reselect columns each time.
To create a new column set:
  • Open the Manage Columns option from the View menu in the Manage Recommendations table.
  • Choose or remove the desired columns.
  • Select Save Column Set to store your configuration.
Figure 10-3 View Menu - Manage Columns - Save Column Set
To access a saved column set, click Load Column Set and select the preferred column set name from the list.
Figure 10-4 View Menu - Manage Columns - Load Column Set
Computed Columns
The Computed Columns feature, available in the View menu of the LPO Manage Recommendations, LPO Run Overview, and LPO What-if Results screens, allows you to create custom calculations using existing data fields. For example, you can define a metric like Rec GM % = Proj Margin / Proj Sales and display it in your workspace for better insights and decision-making.
To add a custom calculated metric:
  • Open the Computed Columns option from the View menu in the Manage Recommendations table.
  • Click Create New Column, then provide a column name and choose the desired formatting.
  • Enter the column expression using the available numeric fields, and click Apply, then Done.
The newly created computed column can then be added to the table through the Manage Columns option. Computed columns can be used just like standard columns, allowing you to apply sorting and filtering directly within the Manage Recommendations and Run Results tables, as well as through the Query Builder
Figure 10-5 View Menu - Add Computed Column
Manage LPO Recommendations - Computed Columns
Figure 10-6 View Menu - Computed Column in Table
Manage LPO Recommendations - Computed Column in Tab;e
Query Builder
The Query Builder allows you to build a complex query, with a grouping of columns in the Manage Recommendations and AND/OR logical operators within and between groups (for example, Recommended Price Type = Markdown and (Brand = Green or Markdown Number <= 2) and Remaining Inventory (at BOP>5) between 10 and 20).
For example, a query can now be constructed as follows:
Price Zone Not Contains 'CO' AND (Ticket Price ends with .97 OR Ticket Price ends with .93 OR Ticket Price ends with .87 OR Ticket Price ends with .84)
All records will then be returned that exclude price zones beginning with CO, with ticket prices ending in .97, .93, .87, or .84.
To perform this action, first select the columns, choose the applicable operator (such as =, !=, contains, not contains, or in), enter the desired values, and set And/Or conditions. Nested groups can be created by clicking the three dots beside a column and selecting columns to group within the query. The nested groups are indicated by a vertical line in the left-hand side of the selected column.
Charts
Certain stages have associated charts available on the right-hand side of the display that list tabular data in a chart format.
Figure 10-8 Tables and Their Charts
Process Train
The process train displays the stages of LPO. The current stage is highlighted.
Figure 10-9 Process Train
Process Train
Embedded Help
Embedded help, which you access by clicking the Question Mark icon, provides additional information about the details required by certain fields.
Figure 10-10 Embedded Help
Embedded Help
