B Appendix: Innovation Workbench Tables for LPO
This appendix lists the Innovation Workbench tables used by LPO.
Innovation Workbench uses RSE prefixes for core foundation tables, PRO prefixes for Promotion and Markdown tables, and PRO_REG prefixes for Regular Pricing tables.
The following read-only tables support LPO validation, diagnostics, rule evaluation, recommendation review, integration tracking, and reporting. Availability depends on the configured Innovation Workbench workspace, permissions, and exposed schema.
Table B-1 Innovation Workbench Tables for LPO
| Table Name | Use in LPO |
| PRO_RUN_SANITY_CHECK_RES_VW | Contains errors, alerts, and warnings generated for Promotion and Markdown optimization runs. |
| PRO_RUN_RECOM_OPT_RESULT | Contains optimization results for Promotion, Markdown, and Targeted Offer recommendations. |
| PRO_REG_RUN_SANITY_CHECK_RES_VW | Contains errors, alerts, and warnings generated for Regular Pricing optimization runs. |
| PRO_REG_RUN_HDR | Contains run-level information such as run ID, run name, run status, strategy, scope, optimization dates, created user, modified user, and execution details. |
| PRO_BATCH_REG_RUN_QUEUE | Contains batch queue information for scheduled Regular Pricing runs. |
| PRO_REG_RUN_PRODUCT | Contains the merchandise or product scope included in the run. |
| PRO_REG_RUN_LOC_PZ | Contains the location or price zone scope included in the run. |
| PRO_REG_RUN_REC_ITEM | Contains item-level recommendation records generated for the run. |
| PRO_REG_RUN_REC_ITEM_DATE | Contains effective date information for item-level regular price recommendations. |
| PRO_REG_RUN_RECOM_OPT_RESULT | Contains optimized Regular Pricing recommendation results, including recommended price, override price where applicable, recommendation status, effective date, and export-related information. |
| PRO_REG_RUN_RECOM_DENORMALIZE | Contains denormalized recommendation information used for reporting and analysis. |
| PRO_REG_RUN_RESULT_METRIC | Contains run result metrics available for Regular Pricing runs. For Rules-Based runs, forecast-dependent projected metrics may not be populated. |
| PRO_REG_RUN_SANITY_CHECK_RES | Contains validation, warning, alert, and error information generated for a run. Review this table when a run ends in Failed status or recommendations are not generated as expected. |
| PRO_REG_RUN_PRICERECOM_INT_ERR | Contains integration error information related to regular price recommendation export. |
| PRO_REG_RUN_OPT_RULES | Contains the rules evaluated during optimization for the run. |
| PRO_REG_RUN_OPT_RULES_REC_DTL | Contains item-level rule evaluation details for generated recommendations. |
| PRO_REG_RUN_OPT_RULES_RELAX | Contains relaxed or violated rule information when the best feasible recommendation is generated. |
| PRO_REG_OPT_RULES_BAD | Contains rule validation issues identified before or during optimization. |
| PRO_REG_RUN_PRICE_LADDER | Contains price ladder information applied during the run. |
| PRO_REG_RUN_PRICE_MATRIX | Contains price matrix information applied during the run. |
| PRO_REG_PRICE_MATRIX_HDR | Contains price matrix header setup information. |
| PRO_REG_PRICE_MATRIX_DTL | Contains price matrix detail setup information. |
| PRO_REG_PRICE_MATRIX_BAD | Contains price matrix validation issues. |
| PRO_REG_COMP_PRICE | Contains competitor price information used by competitor-based Non-Forecast rules. |
| PRO_REG_PRICE_COST | Contains price and cost information used by margin, cost change, and price range rules. |
| PRO_REG_PROD_PACK | Contains pack item information used when pack pricing rules are applicable. |
| PRO_REG_RUN_PCM_OVRD | Contains run-level override information used when recommendation prices are overridden. |
| PRO_REG_RUN_ORULE_REC_PR_RANGE | Contains optimized rule recommendation price range information used during rule evaluation. |
| PRO_REG_PROD_LOC_CDA | Contains product-location custom data attributes that can support reporting and analysis. |
| PRO_REG_RUN_REC_PROD_LOC_CDA | Contains run-level product-location custom data attributes associated with generated recommendations. |
| PRO_REG_BASE_PERIOD, PRO_REG_RUN_FCST, PRO_REG_INVENTORY, PRO_REG_PRICING_OBJECTIVE | These tables primarily support Forecast-Based Regular Pricing analysis. |
