H Appendix: Regular Manage Recommendation
This appendix covers both Forecast-Based and Rules-Based Regular Pricing. Forecast Only fields may be blank for Rules-Based runs. Review current and recommended prices, rule compliance and violations, No Recommendation and Auto Approved outcomes, and export status.
Column Heading Default (Y/N) Applicability (Forecast or Non-Forecast/Rules- Based) Definition DB Reference / Calculation
Image Y Both #N/A N/A
Flag Y Both Users can flag the recommendation for further review. PRO_REG_RUN_RECOM_OPT_RESULT.FCST_REVIEW_CODE
Notes Y Both Users can enter any comment for the recommendation. For example, Additional Budget received so overriding to a deeper markdown. PRO_REG_RUN_RECOM_OPT_RESULT.FCST_NOTE
Ovrd Status Y Both Shows whether the item has any pending recalculate. It shows which user requested it. PRO_REG_RUN_RECOM_OPT_RESULT.CHANGED_BY_USER
Company Y Both
Location of the item recommendation. (For e.g Region, Channel, and so on). Corresponds to the run location setup level. Will be chain when using price zones.
PRO_DB_PARAMETER_VW; #PRO_LOC_HIER_PROCESSING_LVL = 1 (RSE_HIER_LVL)
RSE_LOC_HIER
Item Descr Y Both Item description, external code, and name separated in different columns
RSE_PROD_HIER.DESCR
RSE_PROD_HIER.HIER_LEVEL_ID=8
Brand Name Y Both Name of the brand. RSE_PROD_GRP.NAME
Price Zone Y Both Price zone of the item recommendation. Corresponds to the run setup level. RSE_PRICE_ZONE and RSE_PRICE_ZONE_GRP
Rec Status Y Both Recommendation status: Ready for Review, Reviewed, Auto Approved, Approved, Submitted, Taken, or Export Failed.
PRO_REG_RUN_RECOM_OPT_RESULT.RECOMMENDATION_STATUS_ID
Join With PRO_RECOMMENDATION_STATUS on ID to get UI_NAME.
Tkt Price Y Both Ticket Price of the item. Reflects TRAN TYPE 0, 4, 8. Rolled up from leaf node levels (e.g. SKU-STORE) using Most Common Value PRO_REG_RUN_RECOM_OPT_RESULT.CURRENT_PRICE
Reg Price Y Both Regular Price of the item. Reflects TRAN TYPE 0, 4. Rolled up from leaf node levels (e.g. SKU-STORE) using Most Common Value PRO_REG_RUN_RECOM_OPT_RESULT.LAST_REGULAR_PRICE
Orig Price Y Both Original Price of the item. Reflects TRAN TYPE 0. Rolled up from leaf node levels (e.g. SKU-STORE) using Most Common Value PRO_REG_RUN_RECOM_OPT_RESULT.REGULAR_PRICE
Eff Price Y Both Effective price of the item. It reflects the recommended price or the overridden or user-added price. If the recommendation is rejected, then it will reflect the ticket price of the item. Calculated during optimization and displayed in the UI.
Eff Rec Type Y Both Effective Recommendation Type of the item. It will be recommended, or the overridden/user added or rejected action. Calculated during optimization and displayed in the UI.
Eff Start Dt Y Both Effective start date of the recommendation. Reflect user date override as well. PRO_REG_RUN_RECOM_OPT_RESULT.EFF_START_DT
Eff %Chg of Tkt Y Both Effective % Change of Average Ticket Value, compared to a previous period (like LFY, LFQ, etc.). Calculated during optimization and displayed in the UI.
Eff %Chg of Orig Y Both Effective Percentage Change of Original Price, compared to a previous period (like LFY, LFQ, etc.). Calculated during optimization and displayed in the UI.
Eff %Chg of Reg Y Both Effective Percentage Change of Regular Price, compared to a previous period (like LFY, LFQ, etc.). Calculated during optimization and displayed in the UI.
Rec Price Y Both Recommended Price of the Item PRO_REG_RUN_RECOM_OPT_RESULT.RECOM_PRICE
Rec Type Y Both Recommendation type of the item: Regular, No Recommendation, or Non-forecasted. PRO_REG_RUN_RECOM_OPT_RESULT.PRICE_RECOM_TYPE_ID Join with PRO_PRICE_RECOM_TYPE on ID to get DESCR
Rec %Chg of Tkt Y Both Recommended Percentage Change of Ticket. Calculated during optimization and displayed in the UI.
Rec %Chg of Orig Y Both Recommended Percentage Change of Original Price. Calculated during optimization and displayed in the UI.
Proj Sls Units Y Forecast Only Projected Sales Units for the Effective Week, including any applied overrides. PRO_REG_RUN_RECOM_OPT_RESULT.OPTIMAL_FORECASTED_SALES
Proj Sls Rev Y Forecast Only Projected Sales Revenue for the Effective Week, including any applied overrides. PRO_REG_RUN_RECOM_OPT_RESULT.OPTIMAL_REVENUE
Proj GM Y Forecast Only Projected Gross Margin $ for the Effective Week, including any applied overrides. PRO_REG_RUN_RECOM_OPT_RESULT.OPTIMAL_GROSS_MARGIN
Last Act Inv Y Forecast Only Inventory for the Last Actual Week (or Processing Week). It is the sum of all inventory components that are configured to be used for optimization. PRO_REG_RUN_RECOM_OPT_RESULT.INV_QTY_LAD
Total Buy Y Forecast Only It is sum of Cumulative Sls Units and the Last Act Inv. Cumulative Sls Units is calculated from the first receipt date. PRO_REG_RUN_RECOM_OPT_RESULT.INITIAL_INVENTORY
Run Id and Name Y Both ID of optimization run generating rec CONCAT(PRO_REG_RUN_HDR.ID,'-',PRO_REG_RUN_HDR.NAME)
Optimization Date Y Both Date of optimization run PRO_REG_RUN_HDR.LAST_EXECUTION_DATE
Recalculation Date Y Both Date when the item is recalculated PRO_REG_RUN_RECOM_OPT_RESULT.RECALCULATE_DT
Recalculation User Y Both User who last requested the recalculate PRO_REG_RUN_RECOM_OPT_RESULT.RECALCULATE_BY_USER
Exported On Date Y Both Date when the recommendation was submitted or approved for export. PRO_REG_RUN_RECOM_OPT_RESULT.EXPORTED_ON_DT
Approved By User Y Both User who submitted or approved the recommendation for export. PRO_REG_RUN_RECOM_OPT_RESULT.EXPORTED_BY_USER
LFY Rev Y Forecast Only Last Fiscal Year Revenue - The total revenue a company made during its most recently completed fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFY_REVENUE
LFYH Rev Y Forecast Only Last Fiscal Year Half Revenue - The revenue from the first or second half of the last fiscal year, depending on the context. PRO_REG_RUN_RECOM_DENORMALIZE.LFYH_REVENUE
LFYQ Rev Y Forecast Only Last Fiscal Year Quarter Revenue - Revenue from a specific quarter of the last fiscal year (like Q1, Q2, etc.) PRO_REG_RUN_RECOM_DENORMALIZE.LFYQ_REVENUE
LFH Rev Y Forecast Only Last Fiscal Half Revenue - Revenue from the most recent half-year period in the last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFH_REVENUE
LFQ Rev Y Forecast Only Revenue from the Last Fiscal Quarter (e.g., Q4 ) PRO_REG_RUN_RECOM_DENORMALIZE.LFQ_REVENUE
LF2Q Rev Y Forecast Only Revenue from the 2nd Last Fiscal Quarter (i.e., the quarter before LFQ - so if LFQ is Q4, this is Q3). PRO_REG_RUN_RECOM_DENORMALIZE.LF2Q_REVENUE
LFY Sls Units Y Forecast Only Last Fiscal Year Total Sales Units - Total units sold across all quarters of the last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFY_SALES
LFYH Sls Units Y Forecast Only Last Fiscal Year Half Sales Units - Units sold during half of the last fiscal year (H1 or H2) PRO_REG_RUN_RECOM_DENORMALIZE.LFYH_SALES
LFYQ Sls Units Y Forecast Only Last Fiscal Year Quarter Sales Units - E.g Q4 of last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFYQ_SALES
LFH Sls Units Y Forecast Only Last Fiscal Half Sales Units, The most recent half-year from LFY (either H1 or H2). PRO_REG_RUN_RECOM_DENORMALIZE.LFH_SALES
LFQ Sls Units Y Forecast Only Last Fiscal Quarter Sales Units, The units sold in the most recent quarter of the last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFQ_SALES
LF2Q Sls Units Y Forecast Only 2nd Last Fiscal Quarter Sales Units, The units sold in the quarter before the last one. PRO_REG_RUN_RECOM_DENORMALIZE.LF2Q_SALES
Ext Code, Name, Descr of - Item / Division / Group / Department / Class / Sub Class / Style / Style Color N Both Product Hierarchy
CONCAT(RSE_PROD_HIER.PROD_EXT_CODE,'-',RSE_PROD_HIER.NAME)
Based on RSE_PROD_HIER.HIER_LEVEL_ID
Chain Ext Code / Name / Descr > Area > Region > District >Location Ext Code / Name / Descr N Both Location Hierarchy. N/A with Price Zones. RSE_LOC_HIER_DH
Ovrd Price N Both Overriden price for the item PRO_REG_RUN_RECOM_OPT_RESULT.USR_OVRD_RECOM_PRICE
Ovrd Price Type N Both Override price type for the item
PRO_REG_RUN_RECOM_OPT_RESULT.USR_OVRD_PRICE_RECOM_TYPE_ID JOIN WITH
PRO_PRICE_RECOM_TYPE ON ID to get DESCR
Ovrd Price %Chg of Tkt N Both The percentage change in ticket price based on user-overridden prices, compared to a previous period or baseline. Calculated during optimization and displayed in the UI.
Rec Accepted? N Both Y or No flag to denote whether recommendation was accepted as is or not. PRO_REG_RUN_RECOM_OPT_RESULT.ACCEPTED_FLG
Proj Inv End of EW N Forecast only Projected inventory at the end of the effective week, including any applied overrides. PRO_REG_RUN_RECOM_OPT_RESULT.OPTIMAL_REMAINING_INVENTORY
Start Dt N Both Start date of the Item. For e.g., 2% ST or 3 weeks from first receipt date. PRO_REG_RUN_RECOM_OPT_RESULT.MODEL_START_DT
Final Ship Dt N Both Denotes the calculated final ship date of the item. Last inventory change date that is older than x weeks (configuration) is assigned as the final ship date for the item PRO_REG_RUN_RECOM_OPT_RESULT.FINAL_SHIP_DT
Sys Recom Price N Both System Recommended Price - Suggested by the pricing optimization system based on the rules, strategies, and algorithms it uses. Calculated during optimization and displayed in the UI.
Sys Opt Sales Units N Forecast Only The number of units the system predicts will be sold at the system-recommended price. Calculated during optimization and displayed in the UI.
Sys Opt Revenue N Forecast Only The predicted revenue based on the system-recommended price and the corresponding system-optimized sales units. Calculated during optimization and displayed in the UI.
Sys Opt Gross Margin N Forecast Only The predicted gross margin based on the system's pricing optimization. Calculated during optimization and displayed in the UI.
Sys Opt Inv N Forecast Only The inventory levels the system forecasts to meet the sales units needed at the system-recommended price. Calculated during optimization and displayed in the UI.
LFY GM N Forecast Only Last Fiscal Year Gross Margin - The gross margin for the entire last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFY_GROSS_MARGIN
LFYH GM N Forecast Only Last Fiscal Year Half Gross Margin - The gross margin for the first or second half of the last fiscal year PRO_REG_RUN_RECOM_DENORMALIZE.LFYH_GROSS_MARGIN
LFYQ GM N Forecast Only Last Fiscal Year Quarter Gross Margin - The gross margin for the last fiscal quarter of the previous year. PRO_REG_RUN_RECOM_DENORMALIZE.LFYQ_GROSS_MARGIN
LFH GM N Forecast Only Last Fiscal Half Gross Margin - The gross margin for half of the last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFH_GROSS_MARGIN
LFQ GM N Forecast Only Last Fiscal Quarter Gross Margin - The gross margin for the most recent quarter of the last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LFQ_GROSS_MARGIN
LF2Q GM N Forecast Only Second Last Fiscal Quarter Gross Margin - The gross margin for the quarter before the most recent one in the last fiscal year. PRO_REG_RUN_RECOM_DENORMALIZE.LF2Q_GROSS_MARGIN
Sys Mkdn Budget Used N Forecast Only The amount of the markdown budget that has been used by the system to products. Calculated during optimization and displayed in the UI.
Max Competitor Price N Both Max competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MAX_COMPETITOR_PRICE
Min Competitor Price N Both Min competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MIN_COMPETITOR_PRICE
Avg Competitor Price N Both Average competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.AVG_COMPETITOR_PRICE
Most Common Competitor Price N Both Most common competitor price of that item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MCV_COMPETITOR_PRICE
Target ST EOL N Forecast Only Business rule - Percentage of sell-through for each product at end of clearance season PRO_REG_RUN_RECOM_OPT_RESULT.TARGET_ST_PCT
Currency Attribute 1 - 30 Y Both User Defined Attribute of Currency Type Flex Fact (W_RTL_FLEX_FACT)
Date Attribute 1 - 15 Y Both User Defined Attribute of Date type Flex Fact (W_RTL_FLEX_FACT)
Number Attribute 1 - 40 Y Both User Defined Attribute of Number Type Flex Fact (W_RTL_FLEX_FACT)
Percentage Attribute 1 - 15 Y Both User Defined Attribute of Percentage Type Flex Fact (W_RTL_FLEX_FACT)
Text Attribute 1 - 30 Y Both User Defined Attribute of Text Type Flex Fact (W_RTL_FLEX_FACT)
ProdAttrValue1 - Prod AttrValue 5 N Both Product attributes selected by the user in the user filter. For example, Brand RSE_PROD_ATTR
