Batch Wrapper Overview
In order for the scheduler to execute the different Merchandising programs, batch wrappers have been created based on the following categories:
Wrapper for Pro*C programs
Wrapper for KSH scripts
Wrapper for Perl scripts
Wrapper for file-based programs
These wrappers validate that the user has sufficient privileges to access required directories. These are sub directories of the ${RETAIL_HOME} directory.
Incoming Directory - Staging directory used for .zip files from external systems to be used as input files in Merchandising programs.
Outgoing Directory - Staging directory used for .zip files generated from RMS programs for use by external systems.
Data Directory - Has 6 sub directories used for File processing and archiving.
In Directory - Unzipped files from the Incoming Directory. This directory is used by Merchandising programs as the source for input files.
Out Directory - Generated output files from Merchandising programs. These files will be zipped and moved to the Outgoing Directory.
Processed Directory - All processed files from In Directory will be moved to this directory. This folder will archive input files.
Reject Directory - Generated reject files from Merchandising programs.
Temp Directory - Temporary directory for unzipping files.
Archive Directory - Output files will be archived in this directory.
Wrapper for single-threaded programs.
Wrapper for multi-threaded programs.
Batch-specific wrappers.
